Engine oil cooler nightmare
Old May 4, 2026 | 02:54 PM
KJJag's Avatar
Wink Engine oil cooler nightmare
Hey, Guys!
I bought a 2008 xk coupe on a whim, while in california. The exhaust note and rear end on this car really speaks to me.
Drove it back home to Las Vegas with a smile on my face… no problems whatsoever.
Two weeks in while doing maintenance work, I noticed the dreaded milkshake in the coolant expansion tank. Cleaned out the “ frot” and noticed some smaller black oil droppings floating around. Coolant level was good.
Car runs great, no codes, no limp mode and no white smoke from exhaust. Changed the engine oil, and no milkshake frot in engine oil or dip stick. This leads me to believe it could be the engine oil cooler. Done a ton of online searching, using chatgpt.
Problem. Due to time restraint, Ive been calling indie jag repair shops, but nobody can/ will do it. They cant get the parts needed.
The jag dealership quoted me close to $1000 for the oil cooler, AND since they didnt have the part in stock and quoted me approx a months time to get the parts, Im thinking of doing it myself.
PROBLEM. chatgpt gave me the gasket parts numbers needed, BUT these numbers are wrong. AJ810959 is the oil cooler I need. Also found that I could use a Ford part 6W83-6A642-AA.
But chatgpt tells me that I need a flat gasket between the engine block and oil housing Jaguar PN: AJ810960, but that is INCORRECT!
Chatgpt suggest a Core kit:
-AJ811889 (2x)
-AJ810960 (1x)
-AJ811888 (set)
I strongly believe these parts numbers are wrong!
I did find the o-ring looking like a black 8 PN: NCE1842AA….should go between the cooler and housing, if I understand it right.
Would love to hear from someone who has done this job on a 4.2 non supercharger, what parts are needed, tips and tricks tondo the job, and if it solved the milkshake problem.
Stressed out, but I’m ok
Old May 4, 2026 | 03:22 PM
kj07xk's Avatar
Search this forum. Someone did use a Ford part successfully. Don’t think it had exactly the same number of ribs, but close, IIRC.
Old May 4, 2026 | 03:26 PM
kj07xk's Avatar
Read this thread:
Oil cooler
Old May 4, 2026 | 03:27 PM
Sean W's Avatar
and this one
https://www.jaguarforums.com/forum/x...t-leak-264300/
Old May 4, 2026 | 05:40 PM
bill_jags's Avatar
Oil cooler - RESOLVED. I replaced the Jag leaking oil cooler (on 2007 xk) with a ford "9C2Z6A642A Engine Oil Cooler 6.2 6.8L For 2008-2018 Ford Models Super Duty". It was identical in size and fittings, just needed to use the original Jag center bolt thru the cooler for proper thread. One minor modification was required on the cooler. The cooler's outer aluminum rim is notched for positioning the oil filter adapter, and the ford positioning is different than that for the Jag. However, it is easy to grind/file this ring to properly position the cooler on the adapter. Anyone needing an oil cooler should consider the ford as it is a small fraction of the cost of the Jag cooler.
reply with any questions and good luck.
Old Yesterday | 07:29 PM
KJJag's Avatar
Thanks for the links, kj07xk and Sean W! I did go through all posts regarding oil cooler on this forum, before posting myself. Very helpful and good info.
bill_jags, did you take the “whole” assembly apart? Housing and cooler?
Since I have a “hard” time finding the gasket that goes between the housing and block, I was wondering if it’s possible to just take off the cooler without taking off the housing, hence eliminating the need for that gasket.
From research, it’s the o-ring/gasket NCE1842AA or the inner core of the cooler that are the culprit for oil in coolant expansion tank.
I have ordered the gasket (NCE1842AA) that goes between the housing and the cooler. But having problem sourcing the gasket that goes between the oil filter housing and the block.
AJ811453-R has been suggested, but when I tried to order through eBay, I get a no match for my 2008 Xk 4.2 non supercharger.
what part/gasket did you use between the oil filter housing and block?
Congrats on doing this job with the Ford cooler👏👏👏
How is your Ford cooler holding up? How many miles have you put on it?
Any tips or tricks you have for me, I’m all ears. I am thinking of doing this with only the front raised.
Thanks, guys!
KJ
Old Yesterday | 09:30 PM
bill_jags's Avatar
first, no problems since the installation, probably over a year ago and maybe 5000 miles. Side by side, you will see no difference between the parts, the exception being the rear ring positioning I mentioned in my post. Probably took about 5 minutes to file it correctly to match the jag one. I do not remember any difficulty in installing the new cooler except the bolt was very tight as I recall. I also do not recall any gasket or o ring issues, but my notes say I replaced the oil filter housing adapter seals at a cost of $14. The only difference was the center bolt thread, hence the need to reuse the original jag bolt. I believe I just did as you plan on doing, jack the front end and access it from underneith. I also recall just following the repair manual instructions, including draining down the coolant to prevent a mess. I also recall having some difficulty accessing one of the three bolts, but succeeded with just ordinary shop tools. I got to mine when I noticed oil below the car pretty quickly, and had minimal cross contamination of oil and coolant, yet I did renew the coolant and changed the oil.
Old Yesterday | 10:04 PM
KJJag's Avatar
Thank you very much, bill! Gives me more confidence to tackle this on my own.
The oil filter housing adapter seal ($14) you are mentioning, is that the black o-ring that looks like a figure 8 ( PN: NCE1842AA)?
You removed and reused the jag center bolt. Was there any o-rings on this bolt? If so, would you be able to find out the part number/s?
What kinda file did you use?
I called up my local Jag dealer parts department, but they couldn’t see a gasket between the housing and the block. Am I missing something?
Thanks for taking your time helping me out bill/guys.
jetpilot1
Mar 13, 2024 04:47 PM
sweeper
General Tech Help
May 23, 2023 03:29 PM
sailorbill
Nov 17, 2022 08:50 PM
Lordpaige
Aug 19, 2019 07:46 AM
Sixx Dogg
Mar 10, 2010 06:25 AM
