Wheels / Tires, Suspension & handling Wheels and Tires. Discuss sizes, fitments, offsets, profiles etc etc Discuss roll bars, springs, shocks etc for your Jaguar
XK8 Strut Mount Upper Front Help ?
Old Mar 17, 2010 | 10:24 PM
H20boy's Avatar
Compare the price of the dealer's with Motorcars Ltd, when the upper mounts were backordered for over 6 months, they fabricated their own and sold a ton.
Other than that...not sure where.
Old Mar 18, 2010 | 11:27 AM
H20boy's Avatar
If you get the upper mounts done, since it's totally apart anyway, get the lower shock bushings replaced...small additional cost, but you won't have to worry about it again.
Old Mar 20, 2010 | 03:16 AM
viscoussquirrel's Avatar
Just a thought here but if i could find the thickness of the rubber in the upper shock mounts I could probably find a place to rebuild the plates using aluminum stock and the ride wouldn't be any worse than what I'm currently living with and it would cost substantially less while never wearing out..
Or better yet I bet I could some place to rebuild it with poly instead of rubber bushing material.
So on that note does anyone know what the thickness is?
Meh...maybe I'll stick a chunk of old tire in there so i can at least feel the difference between metal on metal and some rubber in there....
Old Jun 20, 2011 | 03:31 PM
ossiee's Avatar
Default strut mount
Originally Posted by XKRlover
The Upper Strut Mounts for 2000 XK8 are deteriorated..are there rebuild kits/ bushings that can be used without buying new complete units ? Where is the least expensive parts available for this repair other than the dealer ?
Thanks !! J
check coventrywest.com in lithonia ga. strut mounts cost about 180 each side and the bushings to rebuild cost 155 each side
Old Jun 20, 2011 | 03:32 PM
ossiee's Avatar
Old Jun 20, 2011 | 03:39 PM
ossiee's Avatar
Default strut mount bushings
y not use the same plates and some truck tire it might work. better than nothing. let me know if it works
bamforp
Aug 14, 2024 05:36 PM
ahunt4
Sep 14, 2015 08:17 PM
34by151
Sep 6, 2015 05:14 PM
Tar
Sep 6, 2015 11:24 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
