2002 x-type clicking noise
Old Nov 29, 2008 | 08:40 AM
mascari5's Avatar
Default 2002 x-type clicking noise
O.K, this is my first post in this forum. I just bought a 2002 x-type 3.0 with 69k on it. It is an automatic and drives great. It seems to shift with no issues at all. The only problem is that when I release my foot from the brake I can hear a strange clicking noise. It sounds like a relay clicking. It only seems to happen wiht the brake. The noise seems to be coming from under the stability controll button near the shifter. I tried turning the stability on and off but the noise is still there. Again it only happens when I relese my foot from the brake-Any ideas?
Thanks Joe M.
Old Nov 29, 2008 | 08:54 AM
RudyF6's Avatar
Default RE: 2002 x-type clicking noise
That would be the solenoid that releases the shifter when you step on the brake.
Old Nov 29, 2008 | 09:43 AM
mascari5's Avatar
Is that considered a normal noise or is it a potential problem?
Old Nov 29, 2008 | 01:53 PM
BuckMR2's Avatar
Its a common problem.
Its a new J Gate (breakers much cheaper)
OK to use and there is a small lever on the side of the selector under the J Gate to release from P if it gets stuck.
Old Dec 2, 2008 | 11:21 AM
mascari5's Avatar
So to release it from park I find the lever and move it. How do I get under the j-gate. My guess is that I would have to remove the trim piece around the shifter and than take out the retaining screws?
Old Dec 2, 2008 | 02:01 PM
BuckMR2's Avatar
Lift the trim and the small lever is down on the LH ?? side I think.
Its accessible just by raising the surround and feeling around for it.
Not sure how the surround is fixed as mine is a manual which justs lifts up (no screws).
Old Dec 9, 2008 | 04:44 PM
paul11117606's Avatar
Maybe you could let me know how you get along with that, my 02 x is doing exactly the same thing.
Old Dec 9, 2008 | 04:52 PM
Brutal's Avatar
THE FAULT IS A BAD PARK MICROSWITCH, AS YES ITS ONLY AVAIL WITH A NEW SHIFTER ASSMBLY. BUT IT CAN BE REPLACED WITHOUT REPLACING THE WHOLE SHIFTER BUT USING A PIC TO POP IT UP, CUT THE 2 WIRES AND BUTT CONNECT THE NEW SWITCH TO THESE WIRES AND INSTALL THE NEW SWITCH. YOU ONLY HAVE TO REMOVE THE SURROUND SHIFTER TRIM AND THE KNOB AND J GATE MODULE(THE BLACK PRND) TOP WITH THE 4 TORX SCREWS HOLDING IT TO THE ASSEMBLY
Old Dec 9, 2008 | 07:41 PM
thanks mr brutal, any idea whare i can get a new microswitch?, and about how much should it be?.
Old Dec 10, 2008 | 06:20 AM
JagXV6's Avatar
My '02 is doing the same thing but I usually only hear the clicking when it is cold
outside. The Park switch being bad makes more senseIt didn't seem to me that it
would be a good idea to have the solinoid being turned on and off each time the
brake was applied. I assume the switch is in series with the solinoid and goes
open once the shifter is out of park so no power gets applied to the solinoid
when the brake is depressed???
I'd like to poke around and check that switch out too. How does the wood trim piece
and shifter knob come off? Does the trim just get gentely pryed up and theknob unscrew???
Something tells me the trim piece is not going to be cheap is if I break it!
Old Dec 10, 2008 | 07:49 AM
Dennis's Avatar
ud
Trim Bezel just pops up..Start lifting at the rear end of it first...I never played with the knob..so that's a mystery to me too.
Steviedee1st
Nov 28, 2023 06:32 PM
way2far
Aug 31, 2022 09:26 AM
the whittys
Sep 15, 2015 01:47 AM
raulan
Sep 10, 2015 12:43 PM
avern1
Sep 6, 2015 04:22 PM
