2008 X type grille insert
Old Jan 9, 2011 | 08:57 PM
Lotus16's Avatar
Default 2008 X type grille insert
Im thinking of ordering the 2008 grille insert from mina gallery...but it says "painted" or "unpainted" --- what does "painted" mean? I clicked through the ordering process and there's no specification of color...does it mean primed?
Old Jan 9, 2011 | 10:03 PM
exexpat's Avatar
These grilles need to be color-matched to the car. If you order it unpainted, that it will come with a white gel coat or primered. I ordered mine painted.
Old Jan 10, 2011 | 10:51 AM
Lotus16's Avatar
I would love to order it painted, i just cant find whereto put in the info to specify color.
Old Jan 10, 2011 | 11:25 AM
sidewalkman's Avatar
It comes at the actual order point.
Old Jan 10, 2011 | 01:29 PM
Lotus16's Avatar
Sounds good! I appreciate ur help!
Old Jan 10, 2011 | 08:35 PM
exexpat's Avatar
You can email Chris directly or phone him to make the order. From my experience, paint quality and color match is spot on, so you have nothing to worry about
Old Jan 11, 2011 | 12:57 AM
Lotus16's Avatar
Sounds good, it appears that may be the next thing to do before the body kit....im having trouble finding someone that paints/installs them around here.
Old Jan 11, 2011 | 10:25 PM
exexpat's Avatar
Awesome. Sounds like you are going all out. 2005 OEM sport body kit or something else?
Old Jan 12, 2011 | 06:24 AM
Lotus16's Avatar
What i do need is the whitest runnung lightbulb w/o going hid. I tried 194 silverstar and they are actually more yellow, lower wattage than stock. Auto shop said they would do...not the case. Any suggestions? The 194s wont go to waste tho ill put em in the overheads.
Old Jan 12, 2011 | 08:58 AM
exexpat's Avatar
I used these
From here:
http://autolumination.com/194.htm
They match 6000k HID perfectly. I think anything 11mm diameter and under will fit, but I wouldn't go any larger (and there are plenty 11mm and under options).
Old Jan 12, 2011 | 12:51 PM
Lotus16's Avatar
thanks, il check that site out. i picked up a set of Jamstrait LED 194A's before reading ur post, due to the blizzard outside ill have to wait until tomorrow to try em out.
Old Jan 12, 2011 | 01:38 PM
Hey Lotus, you're talking about the little lights in with the high beam aren't you. I went out on EBay and bought little LED projector type 194 bulbs to replace the running lights and all the marker and license plate lights. They were 1.99 for 10 and 1.00 shipping. So for 2.99 I don't mind trying them, even if I know going in they are asian crap but like I said 2.99 delivered.
Old Jan 12, 2011 | 05:20 PM
exexpat's Avatar
I have wasted >$100 on LEDs in experimentation. Typically the cheap ones are not bright enough and are dimmer than their halogen equivalents. The high beams need a little more output in my opinion since the area is so large to illuminate in there. I think you want something with 4 or more high output LEDs on the one 194 wedge bulb. The one pictured has 8 LEDs and as such it costs $12 for one bulb.
Old Jan 12, 2011 | 05:29 PM
uropnm6's Avatar
the bright ones are done with SMD leds
Old Jan 12, 2011 | 06:31 PM
I just am trying to get away from the anemic looking running light. Really looks stupid when you figure in Canada the DRL is the actual lights (HID in my case) are always on. It's like having the auto light option except that I have to put on the lights (parking) to turn on dash lights at night. So brighter isn't really important, it's the color. I would prefer a white closer to the HID. Everything will change this summer when I pull off the bumper cover, then HID fogs are going in, an intake system, and I'll do real LED replacement. But I'm trying to right now avoid the hassle of resisters etc.
Old Jan 13, 2011 | 02:29 PM
Lotus16's Avatar
i tried responding earlier than this but my phone just wouldnt allow it!! i ordered lights off the autolumination website, seemed reasonable went with 11mm 194's. We'll see!! ill keep yas updated.
Old Jan 18, 2011 | 08:23 PM
Lotus16's Avatar
Lights received!! worked out just fine, i appreciate your help with this and the website link!
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Holden
Sep 5, 2015 03:29 AM
KarimPA
Sep 3, 2015 07:32 PM
dcvickers
Sep 2, 2015 06:14 PM
