Duplicate key (s) for 2006 X-Type
Old Oct 13, 2021 | 02:51 PM
FordX-Type2006's Avatar
Default Duplicate key (s) for 2006 X-Type
Just bought a used x-type, 2006 with only one key/fob (switch-blade type.) Called local Jag dealer to get duplicates. He quoted me $650. Per! Any cheaper suggestions?
Old Oct 13, 2021 | 08:19 PM
motorcarman's Avatar
SONE might able to help?
Forum member that cut some keys for me in the past.
Old Oct 14, 2021 | 06:08 AM
Thermo's Avatar
Veteran: Navy
The only way that you can save money on something like this is to order a blank blade and new keyfob via a service like e-bay. You then have to call around to your local lock smith and some will have the computer that will allow them to access the computer to allow accepting a new security code. That should drop the price down to around $300 or so. But, you are not going to get much less than that.
Old Oct 15, 2021 | 03:18 AM
I've moved your question from General Tech Help to X-Type forum. This is the place to post technical questions about your model.
Old Oct 15, 2021 | 10:50 AM
dh53's Avatar
I second motorcarman, message the user Sone for a better price on keys.
https://www.jaguarforums.com/forum/members/sone-195620/
Old Oct 17, 2021 | 06:57 PM
Sone's Avatar
You have several options.
Briefly, the KEY is the mechanical part that turns the lock in the door, glovebox or ignition. To start the car, you need a TRANSPONDER (chip) that the computer will ping to get the code. Right code, car starts.
Since you only have the one key, I suggest that you check with local auto locksmiths to get prices for CLONING the transponder in the fob. Call around, pricing can vary widely. I can then duplicate your key from photos, (standard or with a fob), and he can install a chip that your car will see as being that one, original key. The big advantage of doing it this way is that it eliminates the risk of losing your one and only key in the mail or FedEx. Tell the locksmith that you will supply the key (or fob), all that he has to do is clone the chip. ANY NUMBER of keys can be made using cloned chips, and the car will think that they are the original.
Next best solution is to remove the transponder chip from the fob and glue it inside the plastic shroud, where it will be pinged. Once this is done, any key that is properly cut will start the car, forever. I can supply you all the cut keys that you like.
If there is someone near you who can run the software which mates transponders to the car, I can make and send keys with original factory chips in them, and they can tell the computer to use them.
The last resort is to send me the key and fob, so that I can duplicate the key and clone the transponder. I really don't like this idea, simply because it kills your car until the keys are sent back to you. If you do this, I strongly urge you to spend the money to FedEx it both ways.
Old Oct 17, 2021 | 07:06 PM
Sone's Avatar
There are chips out there which can be cloned by a local locksmith and installed in a key shell. I can supply keys without transponders for less than $40, so the question then becomes the pricing for the cloned chip.
If he were in my area, I can do the whole job (key and cloning) for under $100 (standard key), as he waits.
Old Oct 28, 2021 | 06:03 AM
stephenniz's Avatar
I went to the Jaguar sealer yesterday to have an extra Fob programed. He said it wasn't a Jaguar one and if they tried to mate it to the cr it could wipe out the computer. I think he was bullshitting me. He proceeded to quote me $ 500.00 for a key. Ridiculous.
How is the transponder chip powered once you put it under the shroud ? Is there a best location for this procedure. I think I am going to go this route. I am going to research locally for getting the keys cut but if I don't have any luck I will contact Sone about having my two extra keys cut.
Old Oct 28, 2021 | 10:00 AM
Sone's Avatar
It's not that he was BSing you, he just doesn't know and was being as cautious as possible. It can't "blow the computer," the computer either accepts it or doesn't. Any Texas Instruments 4D60 chip can be mated to the computer.
The chip is just a glass tube. No batteries, no connections to the outside world. It is powered by the pulse from the sensor. You want the chip as close as possible to the ring around the ignition lock, and tape it in place to test it. Start the car at least ten times, and if it works, use a dab of Shoe Goo to glue the chip in place. I advise mounting it inside the plastic shroud, but some sensor rings are stronger than others, giving you more area that the chip can be mounted in and still work. The windshield wiper wand would be a place to try, for instance.
Old Oct 28, 2021 | 01:24 PM
Squito's Avatar
As a follow up to a different thread (Another door key lock out (Tibbe key)) and applicable to this thread, I just today had a key cloned for my x-type for $165, to include about 45 minutes of work. Locksmith in Kingsport TN cut the tibbe key and cloned the new key chip. Interesting process. He had the tools, software, and knowledge. Not all locksmiths do. I did not get a Jaguar logo key fob that had the remote open/close (available on ebay). The locksmith provided a plain 5-pin tibbe that accommodated a chip that works on Jaguars, so it requires manually locking/unlocking the doors, which is okay since it will be my spare key.
Old Oct 31, 2021 | 09:18 PM
Sonia Toledo's Avatar
Hi, I am visiting a locksmith this coming week to find out if he can program an after market key I plan to buy on Ebay. Will let you know how it goes.
Old Dec 21, 2022 | 10:14 AM
dorkko's Avatar
I'm interested in sending fob for u to duplicate the key and clone the transponder. Can you provide some contact info?
Old Dec 21, 2022 | 09:07 PM
Squito's Avatar
Dorrko,
Let me suggest you contact Tri-Cities Lock & Key in Blountville, TN < https://tricitieslock.com/ >
I suggest you try working with them directly as, technically, there may be a state law related to necessity to show ownership of vehicle, VIN #, etc. I'm not sure. I showed up with the car and the key, had the key number (original owner had entered the number into the owners manual) so it was easy for them to cut and they knew I was the owner. Chat with them and see what they can and cannot do for you. Good success.
Old Dec 21, 2022 | 09:10 PM
Sone's Avatar
Originally Posted by Squito
Dorrko,
Not in the United States.
NYCJAG2006
Sep 18, 2019 04:59 PM
hlwanga
Mar 15, 2016 02:00 PM
mjlaris
Aug 7, 2015 03:39 PM
xtype owner
May 26, 2011 09:11 AM
ringo77
Sep 8, 2008 09:19 AM
