FAQ: EBC Brake Pads Discount
Old Aug 16, 2007 | 09:52 AM
bigdreams05's Avatar
Default FAQ: EBC Brake Pads Discount
www.ebcbrakesdirect.com
For a discount at checkout, type in Scooby58! Special thanks to buckmr2 for the reminder!
Old Aug 16, 2007 | 06:08 PM
Default RE: FAQ: EBC Brake Pads Discount
ORIGINAL: bigdreams05
Part numbers below guys....these are for my 02. Always double check for your own peace of mind of course, but a good starting point and price indicator
Jim
Redstuff Ceramic Brake Pads (Complete axle set, both wheels)
DP31322C 2.15Kg (Actual) £54.59 £64.15
DP31350C 1.4Kg (Actual) £41.20 £48.41
Turbo Groove Brake Disc (One piece, 2 discs per car)
GD1050 7Kg (Approx) £44.00 £51.70
GD981 7.6Kg (Actual) £71.07 £83.51
Old Aug 16, 2007 | 06:25 PM
Jim, you da man!
Old Aug 16, 2007 | 06:38 PM
Thanks Biggie...........but really the likes of Buck, Racer, Jose and others are da men.
You and I?.......We just collate their useful info for others to see...lol
Keep up the good work bro.
Jim
Old Jul 12, 2009 | 08:30 AM
aladamson's Avatar
Please be aware that I used EBC and had problems with them.
Old May 28, 2010 | 09:53 PM
JagXType620's Avatar
What kind of problems? Any specifics?
Hopefully this guy is still subscribed to this thread lol its been almost a year.
Old May 31, 2010 | 04:37 AM
aladamson's Avatar
Default EBC Brakes
Hi JagXType620, Background - I don't want to slate these guys too much and perhaps the problem was with my installation, however, I found that the brake pads were too big and got stuck - perhaps there was too much red paint on my pads. I went for a couple of kays and the pads were scraping on the discs. I could have tried to shave the pads down (around the outside and on the flat side) so that they fitted better, but opted to cut my losses and get new pads direct from jag - I figured if they can't get the size/shape/thickness right then I should just play it safe.
Anyway, EBC weren't very interested in resolving my problem. I've still got a set of red pads in my shed! I used their discs - and they seem OK - I've had them in for about a year and they haven't warped or anything. As I said, perhaps it was the way I fitted the pads... Al
Old Apr 5, 2011 | 07:49 PM
tzhyang's Avatar
I've used EBC greenstuff and they works prefect. I'm quite sure the greenstuff and redstuff shouldn't be different in size.
Old Apr 5, 2011 | 10:56 PM
Brutal's Avatar
I use red stuff on the Jag and green(soon to change to yellow for SUV's) on the Nissan truck. and have installed many sets on customers, never an issue. And depends on your Jaguar, yr and model. Jaguar did at one point use stainless shims on the caliper pad slides. This caused issues and jaguar changed to a larger pad and you discard the shims. Smaller pads dont fir without shims(they rattle like crazy) and the larger ones will bind and not fit if used with shims....just a FYI
H20boy
Dec 24, 2024 03:23 PM
jdzubas
Oct 4, 2015 09:14 AM
ahunt4
Sep 19, 2015 09:49 AM
1964Daimler
Sep 9, 2015 11:28 AM
JagLove86
Sep 6, 2015 10:36 PM
