Funny Noise?
Old Oct 29, 2012 | 02:48 PM
shula's Avatar
Question Funny Noise?
I have a 2003, 2.5, Jaguar X-Type. It started making this noise a couple weeks ago. I took it in to have the transmission serviced, but my mechanic said the trans is sealed and never needs to be changed. Any suggestions? Thanks!
Old Oct 29, 2012 | 08:46 PM
motorcarman's Avatar
I can't really tell what the noise is but here is A TSB for a scraping noise.
bob gauff
File Type: pdf
Old Apr 16, 2013 | 01:25 PM
SBJAG2's Avatar
Aaah, it's exactly my noise. Any resolution?
Old Apr 16, 2013 | 05:51 PM
SBJAG2's Avatar
Anyone? Thermo....PAB...?
Has this site become "How to install hood-ornaments and change light bulbs" only 0.o?
Old Apr 18, 2013 | 06:47 PM
Dr dome's Avatar
If you open the hood, is it coming from the passenger side? It sounds to me like a bad bearing in/or one of the pulleys.
Old Apr 18, 2013 | 08:00 PM
Thermo's Avatar
Veteran: Navy
I was thinking a pulley myself. If it was the power steering pump, when you were moving the steering wheel, it would have changed. Granted, I would tell you to see if the noise changes when you turn on the A/C. If it does, you may have a bearing in the A/C compressor that is going out on you.
I think the next check you need to do is to open the hood and see if you can narrow down where the noise is coming from. You may want to even try removing the tire on the side that the noise seems to be coming from so you can stick your head inside the wheel well and see if you can narrow down the source of the noise.
Old Apr 18, 2013 | 10:41 PM
billbjork's Avatar
Shula
I've had that noise in my 03 X for 100,000 miles but NEVER that loud or sitting still or in reverse, just around 20-30 mph, reminds me of two ton truck gear box noise.I have never investigated it because it always the same, not got worse or better.Yours sounds so much louder and in reverse too almost sounds like a power steering pump that has got air in it or foaming because it's low on fluid. I would some how check the trany level,run it in different (3rd) gear to see if the pitch changes I'm going just on the recorded sound also not hands on.
Old Apr 19, 2013 | 10:47 AM
SBJAG2's Avatar
My Mechanic had a listen to both of the clips i.e. shula's and mine and says we have two different sounds. When I listen again, I think he's right. He says, like Thermo & Dr. DOme, that his is probably a pulley.
We, originally, thought mine was also a pulley...so we replaced them and the belt...to no avail.
Hearing this sound clip:
He thinks it might be a catalytic converter...maybe. But it only makes the noise from cold, under load i.e. moving. It goes away quickly especially now as I've learned that if I very easily give it gas and let it change gears on it's own i.e. not mash the pedal down, it goes away in a couple of blocks.
I'm going to leave it with him over night on Monday so he can hear it Tuesday morning.
In the meantime....anyone care to venture a guess?
Old Feb 22, 2014 | 11:08 AM
UKnFor-dluv-expat's Avatar
Originally Posted by billbjork
Shula
EXACTLY! Sounds like a granny gear on an old truck, but intermittent. Mine happened immediately after changing the atf I used idemitsu k17 compatable racing oil Any body let me know if they figured it out!
JimC64
31
May 30, 2016 03:04 PM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 06:43 PM
ChrisJay
Sep 27, 2015 09:08 AM
UKnFor-dluv-expat
Sep 26, 2015 08:40 PM
