Oil drain plug leak
Old Jan 22, 2012 | 11:20 PM
teflondon's Avatar
Question Oil drain plug leak
Hey jag family. I've noticed recently that I'm leaking from my oil drain plug. What a quick fix or should I just order a new one ?
Old Jan 23, 2012 | 07:13 AM
iownme's Avatar
you can go to any auto parts store and buy a nylon or copper sealing washer to put on the drain plug. That should permanently fix it.
Old Jan 23, 2012 | 07:26 AM
reyesl's Avatar
Yes you can, and since the engine has FORD roots, you might be able to get the bolt. I would call around to several stores and check on a drain plug. As far as the gasket, check in the "Emergency Fix" section in most auto parts stores.
Part # XR820128
Old Jan 23, 2012 | 08:34 AM
motorcarman's Avatar
The original oil pan drain plug has a rubber ring built into the plug. The drain plug does NOT need to be that tight but people do overtighten them or use a different plug without the rubber seal.
The dealer issues a new plug at every oil change but they can be used several times before the rubber becomes damaged or distorted.
Is the threaded area stripped????
bob gauff
Old Jan 23, 2012 | 04:44 PM
iownme's Avatar
mine does not have a rubber ring built in. I imagine the previous owner replaced it
Old Jan 23, 2012 | 05:19 PM
Stickman's Avatar
I would just pop over to the dealer and buy a new one. The Jag part with the O-ring works good, just don't tighten it to death.
Old Jan 23, 2012 | 06:56 PM
teflondon's Avatar
Default Is it stripped
Nah the nut isn't stripped
Old Jan 23, 2012 | 07:54 PM
BigCat3153's Avatar
Banned
I was the unsuspecting patsy in the "drain plug switcheroo" scam once. My '86 SAAB turned up with a "stripped drain plug" at the repair house, who, in a remarkable feat of mechanic strength, so they would have me believe, was able to "save" the threads in the pan actual, but, in the process, "lost" the threads on the drainplug actual. Coincidentally, the plug in this case was also an oil temp sensor, which has been impossible to replace so far. I didn't think to ask for the failed plug, but now realize that I donated it to their restoration project, maybe, or some VIP customer got it for his higher ranking machine. I have also lost a wonderful, long, star-head fastener, which pulled the sparkplug cover down onto the head. Even if it were to back itself out, which suddenly after 20+ years seems unlikely, it would have had no where to go. My car went into the repair house with two, and came out with only one.
Moral of the story: If anyone but you has been working on your car, you'd better start inventorying everything before and after you take it in, and get used to the idea of someone stripping or ripping. I'm sorry to sound so glib, but now I'm reminded of the Quicklube joint that must have harvested my really cool hex-head chrome valve stem caps off my pos '03 Trailblazer. They checked the tires and just kept them, I guess. Sorry to lay blame on the above folks when I didn't see them do it, but I didn't do it and you didn't either. Just shoot me.
Last edited by BigCat3153; Jan 23, 2012 at 07:58 PM. Reason: it's spellled "idea" not "ideal you idiot (me = idiot)
Old Jan 24, 2012 | 07:04 AM
iownme's Avatar
sorry to hear that Bigcat3153...not too many people seem to understand the simple principle...if it's not yours...leave it alone.
I'll be working in OK next month...let me know if you need a free oil change
Old Jan 24, 2012 | 05:39 PM
BigCat3153's Avatar
Banned
Absolutely, it's almost that time. Come by the shop when you're here, or let me know where you'll be!
Old Jan 25, 2012 | 07:22 AM
iownme's Avatar
Bigcat3153..PM me your email address or Phone # and i'll contact you when i get to OKC.
Happy to help.
aholbro1
Dec 29, 2024 06:46 PM
Rivguy
Dec 4, 2020 07:55 AM
Scarecrow
Mar 28, 2016 03:17 AM
AL NZ
Sep 4, 2015 08:39 PM
Dymaxxion
Sep 4, 2015 02:40 PM
