Overhead console bulb holder repair.
Old Apr 22, 2016 | 06:37 PM
hlgeorge's Avatar
Default Overhead console bulb holder repair.
[Hope I am not boring anyone with my little homemade fixes!]
(C2S44405 - $50 @ dealer)
In changing out the lamps to LEDs in my overhead console, I broke one of the lamp receptacles on the right reading lamp. My local Jaguar dealer wanted over $50 for a replacement one. I decided to try to repair mine with parts I had on hand. The main part being a T-10 lamp receptacle.
The part holds the lamps for the left & right reading lights and the center front cabin light. It is a clever piece, but doesn’t like the size of the T-10 LED lamp base.
The plastic part is fed electrically via copper buss bars sandwiched within it. I used a bright light to identify where the buss bars were and cut away the plastic on the right reading light that was broken with a Dremmel. I then bent the copper buss up and soldered the leads from a T-10 socket on the buss tabs.
Then I mounted the socket into the lamp holder using my trusty Bondic plastic cold welder. Love this stuff!
Re-installed the lamp holder and all is good.
Hint: When installing LEDs as replacements for Incandescent lamps, clip or file the mounting piece edges so the lamp will slide in the holder easier.
Old Mar 26, 2018 | 06:24 AM
Victor Biriotti's Avatar
Default over head light housing
I know it was a while back. I made a similar faux pas and broke one of the connectors. I had to replace that white lamp housing. ( 2006 X type 2.5 AWD estate )
I am really struggling to get the white lamp hosing back in place under the head lining. I can fit it no problem over the head lining , but getting back in without bringing the entire head lining seems tricky.
When I get it under the head lining it just doesn't seem to line up and the lens cover doesn't clip back in as easily
Any advice or was it just a case of wiggle / patience / determination and hope ?
Old Mar 26, 2018 | 11:17 AM
Default Wiggle and determination...
solved it today Finally, all done .
Old Mar 4, 2021 | 03:35 PM
mateusz1807's Avatar
How to remove this part from the car? I don't want to break something by jerking it unnecessarily
Old Mar 4, 2021 | 03:43 PM
Dell Gailey's Avatar
Under "stickies" on main page.
SEARCH is a marvelous tool
https://www.jaguarforums.com/forum/x...-console-1987/
Old Mar 5, 2021 | 11:39 AM
I don't see anything helpful here. Anyway, I managed to get it out. I don't know if it was correct, but I just pulled it out by force
Old Mar 5, 2021 | 06:32 PM
SEARCH is not restricted to one or any particular accompanying link. Why it's called SEARCH...
https://www.jaguarforums.com/forum/x...onsole-112324/
Post #3 =
https://www.jaguarforum.com/threads/...removal.92202/
Post=1 directly under RED highlighted INSTRUCTIONS =
https://www.jaguarforums.com/forum/x...eds-how-58115/
etc., etc., etc.
Old Mar 6, 2021 | 03:08 AM
on these descriptions there is how to remove the console cover, the part with the buttons from the lights, and I did not ask about it. I asked about the removal of the internal part with bulb sockets, which is shown in the photos.
King Charles
Oct 16, 2019 05:05 AM
310jag
Feb 25, 2019 08:22 PM
Lawrence
XJ40 ( XJ81 )
Oct 8, 2017 08:00 PM
hlgeorge
May 3, 2017 06:51 AM
Don B
23
Oct 18, 2015 11:18 AM
