Sugestion Which Should I buy..00-03
Old Aug 13, 2008 | 01:49 PM
1stJag's Avatar
Default RE: Sugestion Which Should I buy..00-03
My 2.5 is FRUGAL on gas, its also a 5-speed.
I would get a manual transmission jag, so u dont have to worry about the tranny.
Old Aug 13, 2008 | 01:53 PM
rosemont83's Avatar
3.0 liter engine for sure... about the same gas mileage but more power.
I didn't think they made x-types in 2000 or 2001 by the way... but get the latest model with the least mileage you can.
i have a 2002 3.0 sport with a manual transmission so im unsure about the auto tranny problems...
Old Aug 13, 2008 | 02:55 PM
1stJag's Avatar
Trust me rose, if we had to drive across the country.. I'd do it in less trips to the gas station than ur beefy 3.0 gas guzzlin engine
Old Aug 13, 2008 | 04:45 PM
rosemont83's Avatar
But who would have more fun getting there? =]
lol
Old Aug 13, 2008 | 05:32 PM
Jamey's Avatar
Exactly. I just drove mine on a four day trip and loved every single mile.
Old Aug 13, 2008 | 05:41 PM
christo's Avatar
I'm getting 24 miles to the gallon in my 03 with automatic. I think thats pretty good asI am also on my second gas tank since I owned the car so we'll see. Funny thing thecomputer said it was 22 but my calculations were 24. I push the car every once in a while and had the ac on from time to time at a moderate temp.
Old Aug 13, 2008 | 07:53 PM
tarheel72's Avatar
A 2000 X-Type with a Japanese tranny? Hummm, I got to see that.
Old Aug 14, 2008 | 11:28 AM
carlton989's Avatar
go with an 03 or later. they seemed to have a lot of bugs to work out on the 02, which was the first year they were produced. unless you find one with all the recalls being fixed...like mine
Old Aug 15, 2008 | 12:07 AM
jvegas's Avatar
I have had a 03 and now a 05, here is the deal. The 02-03 models had a very big issue. They had bad drain holes in the rocker panels. So if you live in a cold climate area the car is prone to rust… and rust bad! On the x-type the front of the car is lower than the back, so when the salty water gets in the rocker panels and it drains the water sits in the front of the car and cannot drain. Also the 02-03 has a weak tranny, popped air vents, and other lil stuff like that. I would suggest the latest year you can afford. As far as miles…. If you can get a warranty on the car that would be a plus. So maybe 50k or so. The 3.0 is the only way to go. I have had the 2.5 and 3.0 and the 3.0 is a much much better motor. It does not use that much gas.. almost the same as far as mpg’s go. I would also get the auto tranny. As far as I see it, if you want a stick buy a sports car.
Old Aug 15, 2008 | 07:24 AM
christo's Avatar
ORIGINAL: jvegas
Can you please elaborate on this for me - thank you...
Old Aug 15, 2008 | 09:42 AM
jvegas's Avatar
ok, the air vents seem to pop up.. they only to fix them is to super glue them down. i have heard the 02-03 had more tranny issues then the later years. the rust issue is... well.. a rust issue. like most first and second year cars the 02-03 just had some bugs, buy 04 they fixed most of them.
Old Aug 15, 2008 | 10:29 AM
christo's Avatar
I gotcha - thanks bro!
Old Aug 15, 2008 | 11:41 AM
Thermo's Avatar
Veteran: Navy
Christo, you are buying a Jag, yes, parts are going to be a bit more. Granted, if you know what parts are common to every engine and which are Jag specific, you can save some money that way. For example, an oil change requires 6 quarts of oil and a filter. Personally, I am running synthetic in my car (not required, standard 5W30 oil is fine, different story there, check the forums for this). So, the oil change ran me about $28 for the materials and I changed it myself. As for mileage, I am pulling 26 on the highway (70ish) and 18ish in town. I have the 3.0L motor. It has lots of low end grunt due to the variable valve timing. So, no need to get on the gas really hard normally. As for other work on the car, due to the lack of space, it will cost you a bit more. But, this is true of most front wheel drive cars. Just exaggerated with this car due to the inclusion of the transfer case. I am paying $350 a month on a 4 year contract for my Jag. I paid $13.5K out the door. It is an 03 3.0L with all the options other than the sport package and had 80K miles on the ODO.
Chris "Thermo" Coleman
Old Aug 16, 2008 | 08:16 AM
aquill1's Avatar
Well you've already bought one so congrats again!
Old Aug 16, 2008 | 02:36 PM
Cadillac's Avatar
Congrats on your new ride
JohnXJR6
Oct 30, 2017 01:41 PM
Kjallak
Jul 21, 2015 08:10 AM
fourbyfourbyfar
May 6, 2015 07:21 AM
netfix
Mar 8, 2015 07:47 PM
tony bosco
Feb 28, 2015 04:13 PM
