Touch screen
Old Jul 3, 2015 | 03:22 AM
Awelshy's Avatar
Default Touch screen
Hi I have a jaguar X-Type 2.5 auto I went out yesterday and the touch screen isn't working so can't use sat nav or anything can anyone help could it b the heat ?
Old Jul 3, 2015 | 04:40 AM
Welcome to the forum Awelshy,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
Old Jul 3, 2015 | 11:07 AM
dennis black's Avatar
since your in the first phase of trouble shooting
disconnect battery for ten minnute
then let us no ,then we will go with the second phase
Old Jul 3, 2015 | 11:36 AM
Awelshy's Avatar
We have done that the air con works and heater but can't turn off the screen doesn't do anything
Old Jul 3, 2015 | 01:11 PM
phase 2
go to the trunk look for the dvd rom player unplug optics and connectors only on the driver , then turn your car on for 5min, without them plugged in ,shut car off
then plug them in start up car and see what happens
you may have done some of the phases,just follow the steps and we can diagnose each phase
Old Jul 5, 2015 | 01:42 PM
Awelshy's Avatar
hi done phase 2 still not worked we now have no radio as disconnected battery and cannot put code in on touch screen phase 3?
Old Jul 5, 2015 | 02:04 PM
on your deck press the seek button and one of the other buttons marked i cant remember which one but its one of then in the pic
next phase will be software and driver
Old Jul 5, 2015 | 02:17 PM
Awelshy's Avatar
done this does not work by touching still
Old Jul 5, 2015 | 02:25 PM
before we go to phase 3 what trouble shooting have you done before you wrote this thread,i no these phases sond corney but this is common problem and diagnosing can be expensive so let get the minor things out of the way
Old Jul 5, 2015 | 02:28 PM
Awelshy's Avatar
i checked the fuses stated in the manual that work with the unit. disconected the battery. disconected it at the back of the screen unit itself, and pluged them alll back in the right order.
Old Jul 10, 2015 | 04:29 PM
phase 3 load kwi file on disc ,thanks to paulc732
https://www.jaguarforums.com/forum/x...d-link-138788/
if this fails we go to phase 4
Old Jul 13, 2015 | 05:39 AM
twinstacks's Avatar
Hi all. I had the same issue but this was my own fault. I was playing around with the hidden menu and pressed the s/w update menu and got the message can't update from disc and then nothing. I switched ign off and on and now have blank screen and demister on full. I tried getting into the hidden menu again but can't even access that. I can get into the screen menu by holdin temp up, menu and phone I think and that lets me see that the touch screen is all working so I hope its a software issue. I have tried the upload.kwi file but nothing works so I have ordered the latest maps and firmware update to see if this helps. Fingers crossed.
Old Jul 13, 2015 | 04:23 PM
alot of times if you find a dvd rom on ebay it will have the disc in and fix the problem but sometimes the rom you buy has the black screen to,if you get the right loading file then your map disc 80% the time it will work
now ive repaired a few roms and got them working
now if i had no knowledge on files and software and gadgets
i would take my chances with a dvd rom reader on ebay
Old Jul 13, 2015 | 05:28 PM
twinstacks's Avatar
I am hoping it is just the software as when I put my original Jag 2003 disc in the dvd drive it runs and stays running all the time the ignition is on so I am hoping the latest disc with firmware update will sort it out cause if not then am screwed. Can you tell me why the touch screen and all the heater controls gets its software via the sat nav I would have thought it was controlled from the ECU somehow. What is the procedure for updating it in case I am possibly not following the correct procedure. Everything worked perfectly until I stupidly pressed the update button and now nothing works
Thanks for any help given.
Old Jul 13, 2015 | 07:35 PM
remember you need the loading kwi disk not the map disc
Old Jul 14, 2015 | 03:53 AM
twinstacks's Avatar
Thanks. Just got the update disc and put it into my laptop to check what was on it and the upload.kwi is there dated 2008 so ok so far. I inserted disc into car and turned ign off left 20 seconds and turned it on again. The disc is spinning ok and was spinning when I left but 50,51 still flashing. Went and made myself an extra strong coffee and now sitting patiently. Frightened to go back in case it is still the same. Not sure how long it takes.
Old Jul 14, 2015 | 04:38 AM
twinstacks's Avatar
RESULT !! All sorted. Back to working as normal and a semi up to date map. Not sure if they stopped updating this satnav after a certain date but anyway all working now.
Many thanks
Old Jul 15, 2015 | 05:15 PM
no problem happy to help,
take a look at my sat nav with all the bells and whistles
Old Jul 17, 2015 | 06:22 AM
twinstacks's Avatar
JAGUAR X-TYPE CUSTOM MULTIMEDIA SET UP ANDROID NAVTOOL PART2 - YouTube
Spill !! How did you manage to do all this. I was wondering how to get the tv part to work. My sat nav post codes doesn't work either. I am also unsure how to get the phone part of it working. Been in the 1971 menu and can see how to enable them but not sure of much else.
Finbarr1975
Sep 5, 2025 08:38 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
Finbarr1975
Oct 4, 2015 05:32 PM
10 XF Premium
Oct 2, 2015 09:22 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
