x type 2002 2.5 V6
Old Sep 30, 2014 | 06:04 PM
YeshúaMelej12's Avatar
Default x type 2002 2.5 V6
Got a p0303 code misfire on cylinder 3 any ideas what to do in this case, and how to get to this cylinder?... and how to identify it??.. thanks for the help.
Old Sep 30, 2014 | 06:47 PM
Moved to X type section for better help
Good luck
Old Sep 30, 2014 | 07:24 PM
Dr dome's Avatar
Ok if you looking at the front of the engine from the hood(bonnet). Its the center plug closest to the firewall. You have to remove the intake to get to these plugs. You either have a bad coil or there is oil in your plug well.
Good luck,
The Dr!
Old Sep 30, 2014 | 07:45 PM
Good luck,
The Dr!
Thank you very much I appreciate it.
Old Oct 1, 2014 | 10:49 PM
dwclapp's Avatar
In the "How To" section, you'll find some helpful posts for replacing spark plugs.
This thread is a video demonstrating how to remove the intake manifold and change the plugs:
https://www.jaguarforums.com/forum/n...s-xtype-83457/
This thread has good pictures:
https://www.jaguarforums.com/forum/x...nge-faq-48128/
This thread also has good pictures, but one caveat - the spark plugs are incorrectly numbered in a picture. Dr. Dome is correct: plug #3 is the middle plug on the firewall side. But other than this numbering oops, the thread is very helpful.
https://www.jaguarforums.com/forum/x...ted-how-62847/
Old Oct 2, 2014 | 05:13 AM
SteveSheldon's Avatar
I have *got* to do the plugs with this years service - I skipped doing them last year as not at all sure about taking the intake off :-)
Old Oct 3, 2014 | 06:55 AM
Dr dome's Avatar
Default intake
Its really not that hard. After taking the air box off, the the front three are exposed. Now take off the plug on the lower part of the throttle body.take off the 2 lines on the top of the intake.
These are shark grip locks. Push down on the outer ring and pull up on the line. Next take off the big hose going from the intake to the valve cover. Now there are 4 10mm bolts.
One on a bracket behind the throttle body about 4 inches down. The next 3 are behind the intake. holding the wire harness. push the harness against the fire wall. The 3rd one is under the bolt on the right side 4 inches down (looking at the intake from the front of the car).
Next take off the wire clip on top and the 2 on the imt valves. Now use a 8mm and take off the bolts going down into the engine. After taking the 7 bolts off, take the intake up and swing towards the front of the car.
Remember all the coolent lines are still attached. And now you have access to the 1,3,5 plugs.
Any questions feel free to pm me.
Good luck,
The Dr!
Old Oct 3, 2014 | 09:48 AM
Default jaguar x type 2002 2.5 V6
After driving my car with a p0303 code misfire in cylinder #3 for 2 days...I replace the 3 spark plugs under the intake manifold and and didn't do any good...I drive the car for one day had a rough start then went to the store now car won't start.. I try to jump start the battery and all it does it makes 3 clicks it could be a starter problem???...any ideas thanks.
Old Oct 3, 2014 | 09:53 AM
I've merged your post from the general tech section with the previous post on this issue, but check the advice provided to see if it will assist in resolving your problem.
regards,
Steve
way2far
Aug 31, 2022 09:26 AM
Jjscruggs1
Aug 2, 2017 04:40 PM
Raul Lara
Sep 14, 2015 07:31 PM
laserguy
Sep 3, 2015 02:02 PM
Raul Lara
Sep 2, 2015 05:23 PM
