XE ( X760 ) 2015 -
Help installing OEM sport pedal covers
Old Jan 26, 2019 | 03:28 PM
seaxes's Avatar
Question Help installing OEM sport pedal covers
Got the sport pedal covers as a Christmas present. The online instructions make it look real easy http://accessories-instructions.jagu...?2019126182047 but after 2 hours of fighting and cursing I'm at a loss for how to get these things on.
Has anyone successfully put these things on?
Old Jan 27, 2019 | 07:00 AM
I failed to open your link so this operation must be jinxed.
Is it the OE Jaguar Pedal Kit or an aftermarket version? The fitting instructions on Jaguar TOPIx make it appear straightforward:
Old Jan 27, 2019 | 01:04 PM
seaxes's Avatar
Those are the instruction I was following. As you said, it appears straight forward but it's anything but.
Old Jan 27, 2019 | 01:41 PM
Have you got as far as taking the original covers off?
Old Jan 27, 2019 | 01:45 PM
seaxes's Avatar
Yes I pried the original brake pedal off. Can't get that back on either. Step 3 is where I'm stuck, since there doesn't appear to be a way to pull the bottom lip around the pedal with the other 3 lips in place.
Old Jan 27, 2019 | 05:52 PM
Jaguar installation instructions often leave out crucial details. Diagrams alone aren't always sufficient. I think the warning on page 1/2 gives a clue:
DO NOT fit the Sports Pedals using sharp or metal tools
This is as good as saying you won't be able to push them on or engage the bottom lip by hand. It's going to need a plastic or wood tool to pull the lip down so it goes over the pedal.
Old Apr 28, 2023 | 02:53 PM
OldGuy1's Avatar
Know this is a very old thread but I finally bout and installed the accessory pedal covers. While it was a real challenge I found that a "Vinyl Siding Removal Tool" helped a GREAT deal. Thought I would pass that on.
https://www.lowes.com/pd/Kobalt-Sidi...-Tools/3361552
Old May 1, 2023 | 12:59 PM
AZBob's Avatar
I have gotten them on but once in a while they have fallen off. I probably had 3 of the 4 sides on right. My suggestion is to warm them up a little and use a shortie screwdriver from behind to get the lip over the edge of the pedal.
Stuart S
Jun 9, 2021 10:34 PM
Stuart S
Oct 8, 2020 04:23 AM
Don-T
Apr 21, 2018 12:16 PM
Dave Grainger
Aug 24, 2016 08:25 AM
ftypeguy
Jan 3, 2015 02:01 PM
