XF (X260) 2015 onwards
Xf engine problem
Old Jan 10, 2018 | 10:36 AM
Jamiemccowat's Avatar
Default Xf engine problem
Hi Can anyone please help
Xf 58 plate 2.7d auto ,the battery light came on and all the lights on the dash went off with faults on the dash gearbox fault,abs fault and the engine malfunction indicator was on in amber ,I changed the battery and am still getting the same stuff ,cut out on me and will not start
Old Jan 11, 2018 | 03:32 AM
JagV8's Avatar
Read the codes.
Old Jan 11, 2018 | 05:16 AM
Originally Posted by JagV8
Read the codes.
what do you mean read the codes? I don' have codes
Old Jan 11, 2018 | 11:23 AM
Fraser Mitchell's Avatar
Well, your car has them stored. You need to find a Jaguar agent or specialist and get the codes read and assessed. The software will translate the code into a text message indicating the fault area. Most modern cars have these nowadays. It can be as simple as a bad earth, sometimes.
Old Jan 11, 2018 | 02:41 PM
Robman25's Avatar
Or purchase a OBD11 code reader then you can pull down the codes and list them here, someone will respond.
Old Jan 11, 2018 | 05:20 PM
JBzXJ40's Avatar
Yep - definitely need to have the car scanned for codes to see what's been logged.
Did you have any other symptoms before battery light came on and vehicle died?
Have seen problems with ground connection that's below headlights on XF's....
Old Jan 13, 2018 | 09:08 PM
mleskovar's Avatar
What year is your XF??
Old Jan 14, 2018 | 06:24 AM
I think this thread needs moving to the one for XFs up to 2015.
MySTypeAteMyRX7
Dec 18, 2012 02:43 PM
Turbo_dash
Oct 9, 2012 06:28 PM
kenc
Jul 3, 2010 03:59 PM
GTBentley85
Jun 10, 2010 10:03 AM
