air condion broken
Old Jun 14, 2019 | 02:19 AM
Enrico Spoletini's Avatar
Default air condion broken
hello everyone, my jag XF 3.0Diesel 2011
Problem: air condion broken, i set temperature low or 16°C and i have only warm air
-correct coolant gas pressure
-in warm work good
-correct air modulation
what i have to check first ?
thx
E.S.
Old Jun 14, 2019 | 02:32 AM
les's Avatar
les
It could be either the pressure switch on the compressor, or, the compressor itself has failed.
Old Jun 14, 2019 | 02:41 AM
i think about the compressor but before unload the gas circuit I’d like to do some tests.
pressure switch it's good idea
Old Jun 14, 2019 | 03:19 AM
Welcome to the forum Enrico,
I've deleted your other post of this same question from X260 forum.
Here is the Air Conditioning test procedure from the 2011 X250 Workshop Manual:
Are you sure the R134 refrigerant charge is correct? Jaguars lose up to 10% charge weight per year.
Old Jun 14, 2019 | 09:18 AM
lotusespritse's Avatar
Where did you get that info? Neither of my 9 year old Jag XF's wouldn't be blowing ice cold in the Texas summers this year if that were the case.
There's no way this is true.
Old Jun 14, 2019 | 06:44 PM
OzXFR's Avatar
Gotta agree, both my 2010 XFs were still blowing ice cold at 5 and 6 years old and neither had ever had any AC work done on them.
Old Jun 14, 2019 | 07:59 PM
BritCars's Avatar
Same with mine at over 9 years now
AC systems are complex these days but nothing special about the Jag one. I'd take it to an AC specialist and they should be able to diagnose quickly using all the right equipment
Old Jun 25, 2019 | 09:14 PM
timfountain's Avatar
Same here. 10 years old and still blowing ice cold. A/C systems are sealed and should not leak if they are working properly.
Old Aug 2, 2019 | 01:34 AM
Tomy49492's Avatar
My ac went out. Found out it was the cooling fan not turning on and some sometimes fan running at super low speeds
Andrew 07 XKR
Jun 5, 2019 11:14 AM
JagsteRJX
Dec 15, 2016 01:46 PM
alghawia
Jul 15, 2013 11:43 AM
friscoricky
Jul 31, 2011 12:12 PM
