Central locking not working
Old Oct 21, 2024 | 11:33 AM
Smally's Avatar
Default Central locking not working
Hi all, I have an xf 2012 2.2 diesel. Recently I had some small dents repaired by a guy in the rear nearside door. Ever since I have the door open warning light on the dash ( was absolutely fine before), I cannot lock the car anymore and weirdly whatever button on the remote I press the boot lid opens! I replaced the lock on the door today and still have the same problem, can anyone help?
Thanks Steve
Old Oct 21, 2024 | 07:06 PM
POD XF's Avatar
Broken wire in the loom to the door?
Old Oct 22, 2024 | 03:46 AM
Smally's Avatar
Default Makes sense
Given that the dent repair guy actually accessed the inside of the door through the wiring access point in the door it makes sense. Good suggestion. Hope it's not because that would be a giant pain
Old Oct 23, 2024 | 04:25 AM
Smally's Avatar
So I've checked the wiring and all seems to be good, does anyone know if each door has it's own ecu? And if so where it's located in a door?
Old Oct 23, 2024 | 05:31 AM
John Williams's Avatar
Yes each door has it's own module, inside each door, so door card needs to come off.
Old Oct 23, 2024 | 06:14 AM
Smally's Avatar
Hi thanks for the info. Door card already off but where exactly, do you know
Old Oct 23, 2024 | 06:24 AM
POD XF's Avatar
I had my driver's door apart today; the control unit is mounted to the plastic insert that houses the larger of the speakers for the sound system- almost directly behind the armrest on the door. I can't confirm or deny that there is a similar unit in each door.
Old Oct 23, 2024 | 06:33 AM
Smally's Avatar
That's really helpful thanks
Old Oct 23, 2024 | 09:30 AM
Smally's Avatar
Just for clarity it's actually connected to the door card itself on the rear doors
dukeflyer
Dec 5, 2025 02:49 PM
keithyboy
Sep 27, 2025 03:56 PM
A771CUS
Sep 5, 2023 02:24 PM
alljaguars
Jul 5, 2023 11:54 AM
jomo
Jul 1, 2022 08:24 PM
