Help Missing Wheel nut
Old Jul 30, 2014 | 07:33 PM
giandanielxk8's Avatar
Default Help Missing Wheel nut
One of my dad's "10 XF's wheel screw broke off. There is now nothing for that one lug nut to screw into.
(Look at the picture for reference.) Is that sold as a separate part from the rest of the assembly? If so what is the part number? I used to think those were forged into the hub, but apparently according to dad, they're not.
Old Jul 30, 2014 | 07:48 PM
lotusespritse's Avatar
It's hard to tell, but it looks like the bolt part is still there, but the nut is missing.
If the bolt is definitely broken off, your dad should demand the last shop that put the wheels on pay to fix it. I see shops all the time using air impact wrenches to tighten wheels, and that's a big problem. It warps the brakes, and if they get crazy, it will break off the bolt. If torqued properly, the amount of torque applied would never break a bolt.
Old Jul 30, 2014 | 07:58 PM
magmedia's Avatar
Had a wheel stud break off on each of my 2005 x350s.
The Lincoln ls wheel studs are suitable and available nearly anywhere. They are cheap and nearly any mechanic or tire spot can remove the broken part and replace with a new.
I can not say for sure that the xf is the same, but I would not be surprised since wheels and lugs etc are the same.
Should be a sub $100 job.
-mag
Old Jul 30, 2014 | 08:18 PM
magmedia's Avatar
Here's pics with part number.
I hope this works for you.
-mag
Attached Thumbnails Help Missing Wheel nut-image-3137421214.jpg   Help Missing Wheel nut-image-171659516.jpg
Old Jul 30, 2014 | 08:27 PM
Yes, the wheel stud definitely is broken off, it is not still there. Apparently he bought the car like that.
Mag, is that the part for the XJ? I doubt it'll fit, I may be wrong but I think it is more likely that the XJ part be interchangeable with my XK8's than with an XF.
Old Jul 31, 2014 | 05:42 AM
magmedia's Avatar
Originally Posted by giandanielxk8
Yes, the wheel stud definitely is broken off, it is not still there. Apparently he bought the car like that. Mag, is that the part for the XJ? I doubt it'll fit, I may be wrong but I think it is more likely that the XJ part be interchangeable with my XK8's than with an XF.
Ok, thanks. Let us know what you find out.
-mag
Old Jul 31, 2014 | 04:14 PM
Long Islander's Avatar
I think you just whack the stud with a mallot and it pops out the other side. If you look at the picture, there is a spline at the head of the stud which keeps it in place and keeps it from turning when you turn the lug bolt. Buy a new stud from the dealer and take it to a local tire shop and have them do it.
Old Jul 31, 2014 | 06:15 PM
Small problem the only Jaguar dealer in Puerto Rico decided to call it quits. I can only get my parts via online or autoparts stores.
Ok, so the X350, S-Type, XF, X150 and X-type have the same stud size. This makes things way easier. It also seems to be common with many other cars and brands.
Old Aug 1, 2014 | 06:12 AM
Wow, that has to be a real problem when there's no servicing dealer and you live on an island.
Old Aug 2, 2014 | 12:30 AM
You bet! I don't think there is a single '14 or '15 model year Jags in the island.
My hopes of seeing a local F-type are futil.
Old Aug 10, 2014 | 02:32 PM
leadfoot4's Avatar
Go to a site like Advance Auto Parts or Autozone, and plug into your car information, and you'll get a correct part number.
dsnyder586
Dec 29, 2024 07:39 PM
way2far
Aug 31, 2022 09:26 AM
Neil1664
Jan 20, 2022 08:59 PM
jfitzoz
Sep 7, 2015 04:28 AM
JagLove86
Sep 6, 2015 10:36 PM
