XJ ( X351 ) 2009 - 2019
2016 LED headlamp retrofit to earlier cars (with full functionality)
Old Nov 29, 2020 | 02:10 AM
  #281
demiroquai's Avatar
Originally Posted by RTJ 504
where did you buy your headlights? was it plug and play? and how much
So, forgive me for not having the exact lights. The link here is for the non-AFS and that was what I originally purchased but after talking to the seller I paid $300 more for the AFS lights. Also, I worked with a shop here in California that was able to install and attach to the correct fuse.
https://www.ebay.com/itm/A-pair-of-x....m46890.l49292
Old Nov 29, 2020 | 11:01 AM
  #282
RTJ 504's Avatar
Default plug and play
. what you mean for not having the exact light? and yes i seen that ad on ebay i sent him message but he didnt reply yet..i didnt buy cause price was cheap for a pair though it was a scam or sumthin so I have it in my ebay cart right now so the afs version was plug and play as well? cause i was Gunna order the ones he have for $2300 and was that company on ebay legit? did you receive in timely manner? can you send me pics or short video of the daytime running lights and turn signals? once i see yours and you confirm they good ill go ahead and purchase i already have a shop that would install them on..sorry for the long message just wanted to get it all out in one tex lol
Old Nov 30, 2020 | 10:26 AM
  #283
RTJ 504's Avatar
? I need you man lol im ready to buy just need to kn o he good and also is your headlights still function well? since u brought them no issues or lights displaying on your dashboard
Old Mar 26, 2021 | 04:09 PM
  #284
OBC John's Avatar
Originally Posted by xdave
John, you've gone and built yourself a police car!
(I'm making the assumption that the wires in the adaptor harness are a suitable gauge to not increase the resistance, and the diode between position 14 on the old connector prior to any taps is suitably rated.)
I would probe position 8 at the rear of either headlamp with either a scope or multi-meter to see if the voltage drops when that flashing occurs. Also check the resistance to ground from position 9.
I wonder if the JNC/BCM is cutting the AFS motor power or some property of the mosfet is slightly different between our cars causing yours to briefly trip the overpower protection on that circuit. It won't do it when the dipped beams are on because there are multiple paths.
Position 11 at the new headlamp is the main LED driver power. It is normally connected to the battery voltage at all times, with its operation controlled over the LIN on position 16 that is lacking on the earlier cars. As a test, you could try removing pin 11 from the new connector and instead connecting the headlamp position 11 directly to battery voltage and then testing the functions. If that works, you can add a relay across either 14 to GND (1/9/16) at the car connector side, or use any other switched source in place of 14. If it is easier you can snip the wire and use a solder sleeve to repair it if it doesn't make any difference.
Resurrecting this old thread for a quick update.
Firstly, I have to report that Jez is currently quite poorly (not COVID related) but undergoing treatment and I hope I'll be pestering him again soon.
As I posted previously, we did cure the flickering lights by running a switched feed from the engine junction box directly to pins #8. And all was well . . . . well almost. Two things remain: on first morning start-up, if the light stalk is at "Auto" and the headlights come on, the AFS warning shows on the dash. Strangely, this does only happen on first start after which it doesn't happen. A quick ignition cycle clears the warning.
The second thing is that if the side lights are left on when the engine is stopped, the front lights will go off when the car systems shut down.
Today, following @xDaves suggestion in his post above, I ran a permanent live to pin #11. No change. Lights still function but with the same issue. (Don't know about the AFS warning).
Don't know where to go now. TBH, the lights are working 98% as they should but the OCD in me wants them perfect.
Old Mar 26, 2021 | 05:52 PM
  #285
demiroquai's Avatar
I don’t know how I missed this. I’ve had the lights on my car for about eight or nine months now and I’ve had zero issues with them. Everything is working as expected and very well.
Old Mar 26, 2021 | 07:06 PM
  #286
phillyS1's Avatar
Agreed, they are perfect I don't have the car anymore but had the nee lights on for about anyway they were perfect. I had mine retrofitted to be plug and play. Just piped them in and plugged in the wire. Full afs and all auto worked perfectly best upgrade you can do to these cars
Old Nov 11, 2021 | 05:27 AM
  #287
OBC John's Avatar
A final update (I hope).
Despite what I said in my last post about the permanent live, I tried it again but this time physically swapping pins #8 and #11 on the 2016 connector and finding an unused but permanent live in the engine bay junction box. And hey presto!, all the previously mentioned issued have gone. Also, the remote headlight button on the key fob now works (it didn't previously).
I've modified xDave's wiring diagram and attached it here.
File Type: pdf
Old Nov 13, 2021 | 10:18 AM
  #288
clubairth1's Avatar
Community Influencer
Thank you for the update. My only error is if the car is started with the stalk in the high beam position causing an AFS error. Which is cleared by starting the car without the headlights on bright. I will make the wiring mode you posted and that should eliminate that error I hope.
Old Nov 16, 2021 | 01:19 AM
  #289
Larryc's Avatar
Default Lin Bus Question
You mention adding a module to make the car communicate with the newer headlights for say the cornering lights, but only went over opening the lens to change the internal wiring. Is it possible to add this module before the headlamp connector so that everything will work? If so, how and where to get the parts?
Old Nov 16, 2021 | 01:45 AM
  #290
Larryc's Avatar
I’m absolutely loving the look of the 2016 headlights on my 2011 XJ but find myself REALLY missing the cornering light function of my old headlights (yes new ones are AFS too) is there another way to get these to work without opening the lenses? Thanks
Old Nov 16, 2021 | 01:44 PM
  #291
OBC John's Avatar
The OP says that the LED headlight units contain a separate driver for the static cornering lamps which has to be rewired to get them to function. You need to open the unit to access it, so it can't be done with external wiring.
It's really not an issue for me.
sanchez
Jul 14, 2018 03:39 PM
iramphal
Mar 28, 2018 07:54 AM
gmsclassics
Jan 27, 2018 09:10 AM
romroc
Sep 7, 2017 10:15 AM
adenshillito
Mar 5, 2017 12:59 AM
