2006 XJ8
Old Feb 11, 2026 | 06:28 PM
farmerboy's Avatar
Default 2006 XJ8
I have had my XJ8 in storage over the winter. I had removed the battery to keep it on trickle, when I put back and hooked it up my car started right away but my brake will not release, would it have something to do with the battery being removed ???
Old Feb 12, 2026 | 12:54 AM
cat_as_trophy's Avatar
Absolutely! Common on all Jag EPBs of this era.
A timely reminder that isolating the battery for long periods will trigger the need to re-calibrate the EPB. Sometimes this is a requirement eg engine rebuild or extensive electrical or body repairs but, generally, should be avoided just for over-wintering in those climates that need this . . . because modern "smart" chargers or "battery maintainers" (C-Tek etc) are designed to be permanently connected, stepping down when battery is fully charged, but kicking back in when the battery depletes.
Back to re-calibrating . . . use search tools . . . read the process . . . then print and keep a copy in glove box. Easy peasy!
Cheers and best wishes
Old Feb 12, 2026 | 02:49 AM
JagV8's Avatar
Once you get it working, if you've a paddle for it then when next you want to store the car stop the EPB applying by holding the paddle down as you remove the key.
At least that way if it sticks it sticks off.
Old Feb 13, 2026 | 06:44 PM
^ ^ ^ +1 +1 +1 +1 ^ ^ ^
Thanks John. I do this so automatically whenever I garage mine, that I'm guilty of forgetting to mention it.
Cheers and best wishes,
Old Feb 13, 2026 | 07:17 PM
farmerboy's Avatar
Thank you all good now !
Old Feb 13, 2026 | 07:31 PM
wfooshee's Avatar
You have to recalibrate your auto-up windows, too.
Old Feb 18, 2026 | 12:36 PM
farmerboy's Avatar
Default 2006 XJ8
Thank you everyone, the brake problem was fixed using your fixes. Still have a problem with the tire fault. Checked again the pressures made sure all was good, drove for a number of miles, but still got the fault message.
Old Feb 19, 2026 | 12:18 PM
jbellK75's Avatar
American here, what's a paddle? Thanks.
I'd have the wheel sensors checked. Most tire shops have the meter to do that if you don't have one. Some cars the sensor battery can be checked through OBD2 but I don't know about the XJ8. The battery in them typically lasts 12-15 years.
Old Feb 20, 2026 | 02:34 AM
JagV8's Avatar
Try the handbook info about the EPB
Old Feb 20, 2026 | 05:00 PM
chemosabe's Avatar
I believe JagV8 is referring to the paddle/lever in the middle console that can be pulled up or pushed down to set or release the epb
Old Feb 21, 2026 | 04:49 AM
JagV8's Avatar
Phew, yes that paddle.
Old Feb 21, 2026 | 08:56 AM
jbellK75's Avatar
Got it, thanks.
gregoryzim
Jul 11, 2021 11:29 AM
adam699
Aug 2, 2013 08:34 PM
nahidik
Nov 1, 2009 04:29 AM
Feb 25, 2007 05:31 AM
