Amber light:Restricted Performance no check engine light
Old Jan 10, 2019 | 09:52 AM
Mike-Ko's Avatar
Default Amber light:Restricted Performance no check engine light
Just went back for vacation yesterday, everything is fine.
But this morning went up an amber light showed Restricted Performance and without check engine light.
It disapeared when my car's speed over 90KM for a while and showed up again when idle.
I can not over 3000RPM, once I reach at 3, it will shake a lot. The Scanner shows No.1 cylinder too lean sometime, theres no other codes.
Mess air flow? Or any idea?
Old Jan 10, 2019 | 10:35 AM
Wingrider's Avatar
Number of code is???????????
Old Jan 10, 2019 | 10:45 AM
Mike-Ko's Avatar
Sorry I forgot to write it down
Old Jan 10, 2019 | 01:16 PM
Wingrider's Avatar
Not hard to do, if you want to play at fixing your toy yourself.
Buy a code reader, that can read Jaguar codes.
Great investment, a basic tool to have!
Old Jan 13, 2019 | 05:16 AM
Mike-Ko's Avatar
Code P0171, P0174
Old Jan 13, 2019 | 05:41 AM
Partick the Cat's Avatar
P0171 Left-hand cylinders combustion too lean
P0174 Right-hand cylinders combustion too lean
In both cases the following are given as possible causes:
• Air intake leak between mass air flow (MAF) sensor and cylinder head
• Fuel filter/system restriction
• Fuel injector restriction
• Fuel rail pressure (FRP) sensor fault (low fuel pressure)
• Low fuel pump output
• HO2S/catalyst monitor sensor harness wiring condition fault
• EFT sensor fault (low fuel temperature)
• Mass air flow (MAF) sensor system, <<309-00>> For fault (low intake air flow)
• Exhaust leak (before catalyst)
• ECM receiving incorrect signal from one or more of the following sensors; ECT, MAF*, IAT, fuel rail temperature
Old Jan 13, 2019 | 07:56 AM
Mike-Ko's Avatar
So I used my SDD to see, only shows P0171&P0174.
Maybe I should replace MAF first? Because I did not see any other codes comes up.
But the fuel pump output, I feel my car has more power when the tank is full...... is that my psychological problem??
Old Jan 13, 2019 | 10:07 AM
JagV8's Avatar
Check fuel trims (many threads with details) rather than parts-swapping.
Old Jan 13, 2019 | 03:44 PM
meirion1's Avatar
How many miles on the Jag?
Old Jan 13, 2019 | 04:28 PM
Wingrider's Avatar
Chased my vacuum leak down to those eight pesky rubber gaskets inside the intake manifold.
The car always ran great, but the check engine light kept coming on till they were replaced.
Old Jan 16, 2019 | 07:34 PM
Harry Peter Rose's Avatar
did you ever resolve your problems ?......if so how?
Old Jan 17, 2019 | 10:31 AM
Mike-Ko's Avatar
Sure, fuel system is fine.
Old Jan 17, 2019 | 10:32 AM
Mike-Ko's Avatar
99211 miles only.
Old Jan 17, 2019 | 10:37 AM
Mike-Ko's Avatar
I used a screw driver knocked my MAF for few times, the light went off sometimes.
So I ordered a new one and replaced it yesterday, the light never show up today.
But I dont know does it fixed or not, it seems solved but not sure.
The code vanished.
Old Jan 17, 2019 | 11:28 AM
Wingrider's Avatar
Good sign so far;
Old Jan 19, 2019 | 10:33 AM
Mike-Ko's Avatar
Originally Posted by Wingrider
Good sign so far;
it seems cured for now
Old Jan 20, 2019 | 01:59 PM
codes P0171 PO174 ..ervice guy has replaced sensors /fixed seals etc....BACK TO GARAGE ...4 times in 3 months HE clears codes and I drive 20 mins and engine light and amber warning come back on!
Old Jan 20, 2019 | 05:12 PM
JagV8's Avatar
Clearly he is useless. Persist if you like.
It needs proper diagnosis and then a fix.
DIY or find a competent tech.
To DIY read the many threads on those codes.
Old Jan 20, 2019 | 06:27 PM
Wingrider's Avatar
JagV8 gave you some great advice, heed it.
Get off your rump, get a scanner, and get busy.
Unless your wealthy, & lazy, then find a decent tech.
They are a car after all, most of us feel good about d i y, and the money it saves.
jeremys
Sep 30, 2015 06:37 AM
the xkr man
Mar 17, 2013 07:04 PM
bigevent
Dec 31, 2012 05:29 PM
loblue
Aug 1, 2011 12:17 PM
SunnyType
Jan 9, 2008 06:14 PM
