Bonnet Open
Old Jul 20, 2020 | 03:52 AM
BDuncan's Avatar
Default Bonnet Open
Hi, Can anyone help. I have a red light coming on ,, on the speedometer and a Message "Bonnet Open" I checked the bonnet and its fine. Does anyone know where I can find the bonnet switch / sensor so I can check it out.
Old Jul 20, 2020 | 06:22 AM
mhamilton's Avatar
The switch is part of the latch and is separately replaceable. Part C2D27159. Common failure item actually. I got mine from the dealer.
Old Jul 20, 2020 | 06:50 AM
Wingrider's Avatar
A paper clip in the connector of both of mine solved the issue for me.
The location is on the drivers side hood latch, an easy replacement, or bypass.
Old Jul 20, 2020 | 07:38 AM
BDuncan's Avatar
Thanks very much for the help. Cheers
Old Jul 20, 2020 | 11:32 AM
Partick the Cat's Avatar
Ah ha ! Beware ... Driver's side in the US (LHD) ... Passenger side in the UK !
Old Jul 20, 2020 | 11:36 AM
Wingrider's Avatar
Old Jul 20, 2020 | 03:14 PM
JX350's Avatar
In your case it'll be the switch as others have suggested. I kept getting the 'bonnet open' red light warning when driving along. When I inspected the bonnet it was actually open, only a little, but it was open. I released the bonnet and found that it would not shut without really slamming it down. When it eventually engaged it would ping slightly open again once I was driving. I greased up the latches and that solved the problem. The latches seem to seize up and will eventually start to release the bonnet when driving or going over bumps.
I hope you get it sorted.
Thanks,
Chris
Old Jul 20, 2020 | 04:04 PM
The problem is supposed to be caused by oil from the lock mechanism working its way down into the innards of the switch and getting on the contacts. Jag's solution is, allegedly, 'don't oil the lock mechanism'
I shorted mine out with a bit of aluminium foil from a Kit-Kat bar.
Old Jul 21, 2020 | 09:26 AM
BDuncan's Avatar
Patrick the Cat,
Thank yes its on the Passenger side. Cheers
Old Jul 21, 2020 | 09:28 AM
BDuncan's Avatar
XJ350,
Thanks for the info, will make sure I grease it up when I change the switch / sensor.
Old Jul 22, 2020 | 10:10 AM
Wingrider's Avatar
Spraying the contact points, with a contact type cleaner, might solve the issue.
Worth a try if you have a can setting around.
Many of us do for some reason.
Old Jul 23, 2020 | 02:28 AM
BDuncan's Avatar
Wingrider,
I removed and sprayed the contact points 2 days ago. And no more "Bonnet Open" warning Lights. Thanks for your help (All of you)
Old Jul 25, 2020 | 03:20 PM
JX350's Avatar
Glad you got it sorted Bruce
Old Nov 10, 2020 | 09:44 AM
stephen44's Avatar
Default bo
I am in the UK - so above drivers side is that usa or uk driver?
ty - Stephen
Old Nov 10, 2020 | 09:53 AM
stephen44's Avatar
could some post a picture please of where the paper clip needs to go
regards Stephen
ignore sig - i cant work out where to edit
mosesbotbol
Oct 5, 2023 10:20 AM
mrcoco
Aug 11, 2019 09:58 AM
Adam Lueb
Apr 14, 2011 05:04 PM
tanngo
Jul 31, 2010 10:29 PM
chupacabra
Apr 25, 2009 12:39 PM
