Cupholder replacement/options
Old May 23, 2013 | 04:29 AM
TallXJDriver's Avatar
Default Cupholder replacement/options
At the risk of sounding like Homer Simpson is a classic Season 2 or 3 episode (the one with Danny Devito as car maven), the tiny cupholders in the X350 have got to go.
I found this part on a dealer's website and wonder if it holds bigger cups:
CUPHOLDER IN CENTER CONSOLE - C2C26874 (It says it replaces another part so maybe it replaces original cupholder. It looks like maybe one cup is larger -- probably the driver's side.)
The X350 is crying out for some aftermarket cupholders. Forget aftermarket wheels, etc. We need some cupholders.
Maybe we could "bore out" the existing cupholders like cylinders in a Harley engine to increase the cc's. I would even put a chrome badge on my trunk lid with something like "HCC" for High-Capacity Cupholder."
Old May 23, 2013 | 03:15 PM
I can't be the only one tired of holding drinks while I'm driving because they won't fit in the cupholder.
Old May 24, 2013 | 05:47 AM
James Lewis's Avatar
that may be a super v8 cupholder they had different ones fitted like the x308/xk with it fitted to the front of the arm rest
Old May 24, 2013 | 06:15 AM
Cambo's Avatar
Why stop at a cupholder?
But seriously...that p/n C2C26874 is only listed for X350's with VIN G45172 onwards, and it appears that there is no backwards compatibility.
Don't know what year / VIN yours is though...
Interesting that the one in this ebay sale New Jaguar XJ8 2004 2009 Center Console Cup Holder C2C26874 | eBay definitely shows one being bigger than the other.
For $27 it might be worth the punt, but I doubt it will be a straight swap...
OR
Just try removing it completely? https://www.jaguarforums.com/forum/s...-my-str-52085/
Attached Thumbnails Cupholder replacement/options-homer.jpg
Old May 25, 2013 | 04:30 AM
Cambo, do you cupholders pop out that easily? I might buy that other piece just in case it fits. A $25 fix for the undersized cupholders would be a huge benefit.
Old May 25, 2013 | 04:54 AM
OR
By the way, is that a picture of an actual Homer or a model of one? I did not know they actually went into production. Powell Motors had a good run.
Old May 25, 2013 | 05:21 AM
Cambo's Avatar
After reading the thread in the S-Type forum, I went out to the car dreaming of a big wad of £50 notes being stashed in there by the previous owner. The cup holders came out to reveal....nothing except the little rubber tray...
But they do come out, just pull in the middle between the two circles.
No idea about the Homer, I just googled it....
Old May 25, 2013 | 09:08 AM
310jag's Avatar
The C2C26874 replaces the older style (soft finish, symmetrical) cup holder insert. Pull the old one out, removed the rubber tray below, and pop the new one in. Problem solved.
Old May 26, 2013 | 05:09 AM
I'm buying one right now.
Also, I could have owned this car 20 years and never found that compartment under the cupholder. How cool is this car? If you had something like a Big Gulp or a huge coffee mug, you could just go without the cupholder in there.
Cambo, thanks again for the reference to that thread about removing the cupholder.
Old Jun 4, 2013 | 04:52 AM
So I received my new cupholder, and it is a match and holds normal-sized drinks! One hole is bigger and the other is about the size of the stock cupholder holes.
There are no springy things; it's just a plastic cupholder. So not as fancy as stock, but you can actually use it. I recommend the switch.
Old Jun 5, 2013 | 11:44 AM
jacobsos's Avatar
Bought it, installed it in 10 seconds in '04 XJR, love it.
Old Jun 11, 2013 | 03:39 PM
SableCat's Avatar
Default Cupholder removal
When I read this thread I went out and tried to pull the cup holder out of the console. It would not budge, at least not with the amount of force I was willing to exert. I DO NOT want to break my beautiful pet Jaguar.
Last week I was out in the boonies driving a curvy road in the SF Bay area. I stopped for a cold drink at a Burger King. When I returned to the car I had to sort of cram it down into the hole to get it to fit.
A little while later I tried to take a sip and it would not come out! So I sort of wiggled it back and forth while pulling up, and up she comes, cup, cup holder and all!
So, I think I might try the one linked in this thread.
Tom
Old Jun 11, 2013 | 04:51 PM
psg's Avatar
psg
I tried too, won't budge. Does it come out in one piece with the front part of the console/lid?
Stu
Old Jun 11, 2013 | 05:06 PM
Stu
In my 2004 the cupholder came out on its own. It lifted straight up. This is only the plastic cupholder itself. It looks like it is one piece with the console, but the black plastic is held down only by gravity.
Maybe over time various foreign substances get in between the surfaces and make them stick together.
By the way, I am enjoying my car much more with a functional cupholder. I urge everyone to do this. No other $30 investment will change your driving experience to this degree.
Old Jun 12, 2013 | 01:37 PM
SableCat's Avatar
Stu
Just the cupholder itself came out. There is a felt liner that goes around the cavity it fits into, that stays attached to the console.
Try pulling up with more pressure on the rear side. Mine seems to pop out on the rear side first. I just went out and looked at it in my XJ. It is easier if you open the lid on the storage compartment.
I noticed that there is a little divided tray on the bottom of the cavity! I pulled up on it and it came up easily. I suspect its purpose is to catch any condensation drips from the hot or cold liquids in the cupholder. (Its a Jaaaag) The whole cavity is lined with a felt like substance and you do not really need the cup holder to use it. It could be used for additional storage if one wished.
BTW, psg, is that a photo of a Lancaster on your logo?
Tom
Old Jun 12, 2013 | 03:56 PM
psg's Avatar
psg
Yes it one of two flying in the world, this one is flown out of the Canadian Warplane Heritage Museum in Hamilton. it was here in Calgary a few years ago. It did a few low, high speed passes , what a glorious sound those four Merlins make.
Stu
Old Jun 13, 2013 | 01:29 AM
SableCat's Avatar
Stu
I'll bet they do! I recently attended an airshow (Chino California) where they had 5 of the 7 flying P-38s. They had the usual gaggle of Mustangs, Corsairs, P-40's, a Saab Draken, a Spitfire 18 with a griffon motor I think. They had some really rare stuff: One of the 2 flying real Japanese Zero's, even an old F-94 jet fighter and an original Northrop flying wing. They ended the show with a mock dogfight between a Mig 15, a T-33, and an F-86.
About 10 years ago I was heading from Edmonton towards a place called Head Smashed In Buffalo Jump. We came upon a little air museum that had a Lancaster that was being restored to flying condition. Only one I have ever seen.
Planes are great to watch, but they don't give me the little thrill I get when I go out the door in the morning and there is a Jag waiting for me in the driveway.
Tom
Old Jun 14, 2013 | 08:12 AM
ryejag's Avatar
I know this is less interesting than flying old planes, especially since I don't fly them. New cupholder went right in like a charm for me. Some coffee with sugar in the bottom tray in the bottom tray from previous owner. I know the spill is not mine, since I have my coffee black!
RyeJag
Old Jun 14, 2013 | 04:36 PM
34by151's Avatar
Tom
How about driving the jag to the plane!!
2 Planes in the hangar and a seaplane at home and they all give me a thrill just not the same type of thrill
34by151
Old Jun 14, 2013 | 05:07 PM
psg's Avatar
psg
R Fife
Dec 30, 2021 11:34 AM
Hdpartsman00XKR
Aug 7, 2020 09:27 PM
NTL1991
Oct 15, 2014 10:28 PM
tacarten
Aug 30, 2014 08:16 PM
jvitez
Feb 28, 2014 12:32 PM
