Hello, Anyone knows a fix to GearFault (error solenoid valve A)? thanks a lot
It may be a matter of replacing the solenoid but first you need to be able to identify it,
and the confidence to remove mechatronic and replace it.
https://www.thectsc.com/
https://www.jaguarforums.com/forum/x...ooting-191572/
Hello Fellows, sorry for the late reply, I was off on a holiday and just came back. I thought it may be useful to everyone to attach the diagnostic report as conducted at the Jaguar dealership which highlights in yellow the fault codes # P0750 & P1605. They also tried to upgrade the transmission software but they could not due to failure code # 2573. (Attached you may find the diagnostic report)
I believe that explains and illustrates the problem much better than I would. Please come to the rescue ...thanks in advance.
https://www.engine-codes.com/p1605.html
https://repairpal.com/obd-ii-code-p0750
How old is your battery?
It might be too late but I suggest checking the seal where the transmission wiring plugs into the case. It is known for them to spring a leak and adulterate the connectors. The seal is cheap and relatively easy to change. Before committing to a major expense - like changing the transmission, I would do the transmission fluid change, replace the seal mentioned above as well as the tube seals under the Mechatronix unit (very easy to remove). It solved all of my transmission problems for less than $500. If you get as far as removing the Mechatronix, you might consider replacing that solenoid. ZF are very responsive to eMail and can direct you to the solenoid that needs changing. The problem may be that debris is blocking an internal oilway in the valve body or getting in the way of solenoid operation in which case a rebuilt valvebody might be the most cost effective solution. Whatever you do I strongly advise you contact ZF and explain symptoms in detail
Steve
Steve
Steve
Steve
xjrwithproblems
08-16-2023 08:52 AM
Blairware
01-23-2020 05:47 AM
JimC64
03-02-2015 08:07 PM
blackcat2003
08-10-2011 05:59 AM
Michael Jeansonne
06-27-2010 06:08 AM
