How to change the engine filter and cabin filter
Old Nov 25, 2013 | 03:59 PM
Jgmc's Avatar
Default How to change the engine filter and cabin filter
So the dealership said it would cost $115.00 to change the "engine" filter so I ordered the part. Now how do I change it. I saw where the cabin filter goes, easy as pie.
What about the Engine filter? Sorry for the earlier post I got turned around. So it's the Engine Filter. See my last post with photos
I have a 2008 XJR
Thank you.
Video would be great
Old Nov 25, 2013 | 04:57 PM
Fraser Mitchell's Avatar
Cabin filter is a snap.
On the passenger side, you'll see a removable cover with a grill moulded in it. Take this off and you'll see the filter. Its about a 5 minute job, but check the water drain is clear while you're in there.
Old Nov 25, 2013 | 09:48 PM
QuikCat's Avatar
When you do the cabin filter, pay attention to the arrows for air flow, and make sure you install them facing the right direction. When I changed mine, the previous owner had it installed backwards.
Old Nov 26, 2013 | 08:21 AM
edobernig's Avatar
Default Check the How To Section
Originally Posted by Jgmc
So the dealership said it would cost $115.00 to change the engine filter so I ordered the part. Now how do I change it. I saw where it goes, upper left side.
What about the cabin filter? They didn't say that needed to be changed but if it's easy........
I have a 2008 XJR
Thank you.
For Oil Change- Check the "How to Section." Did a step by step with pictures.
https://www.jaguarforums.com/forum/x...-change-67711/
Old Nov 26, 2013 | 03:20 PM
reyesl's Avatar
Question
I have a 2008 XJR
Thank you.
Oil filter or Air Filter? At $115.00 it might be the engine oil, oil filter, and the air filter.
Attached Thumbnails How to change the engine filter and cabin filter-air-filters.jpg
Old Nov 27, 2013 | 02:43 PM
PigletJohn's Avatar
not oil, then.
I answered including a video link
on your other thread dated 11-22-2013, 10:51 PM.
Old Dec 7, 2013 | 09:32 AM
Jgmc's Avatar
No that price was JUST for the engine air filter. He broke down the price for me
Old Dec 7, 2013 | 09:34 AM
Jgmc's Avatar
As much as I would love to save money on oil changes, I will pass on oil changes. I don't know too many women who likes to get that dirty LOL. See below to where my problem is now.
Old Dec 7, 2013 | 09:40 AM
Jgmc's Avatar
Funny, yes I noticed that.
Thank you!!
Old Dec 7, 2013 | 10:52 AM
Jgmc's Avatar
Okay, here I am now. Thanks to Reyesl for photos of where the "engine" air filter is located. How how to remove the cover. The front of the cover is easy, pushing the clips back to unhook. But it is holding in the back. I can't tell if I were to lift (might brake it) push, (might brake it) or what. How do I physically remove it. Here are the photos
Engine: 2008 XJR
Clips: Front of clips (1 of 2)
Clips: Push both to release front (2 of 2)
Back of case, how do I release the back of the case. It won't lift, it's tight. Whats the trick. The service guy said something about being careful not to brake the clips on the bottom.
Thanks!!
Attached Thumbnails How to change the engine filter and cabin filter-4522663.jpg   How to change the engine filter and cabin filter-4522665.jpg   How to change the engine filter and cabin filter-4522664.jpg   How to change the engine filter and cabin filter-4522666.jpg
Old Dec 8, 2013 | 05:19 AM
reyesl's Avatar
Lift up where the clips are, then slide the cover towards the engine to unlatch the tabs on the Engine side. It sounds easy but it is a little difficult. Since I clean my filter monthly and replace it at every oil change, I removed the tabs and are currently using 2 screws to tighten the cover.
Old Dec 8, 2013 | 08:54 AM
PigletJohn's Avatar
see https://www.jaguarforums.com/forum/x...charged-98339/ which has the video
Old Dec 9, 2013 | 10:22 AM
Jgmc's Avatar
Originally Posted by PigletJohn
PigletJohn: Thanks for the video! Does that mean I have to remove the Intake Elbo (that's what the guy said to make it easier - not that I knew that's whats it called). I guess I should play around with it.
Old Dec 9, 2013 | 10:27 AM
Jgmc's Avatar
reyesl, Do you actually feel the difference with your engine by cleaning it monthly?
Old Dec 10, 2013 | 08:48 AM
PigletJohn's Avatar
jgmc
It's possible to wiggle the top off without removing the elephant's trunk, but I suspect that after you've spend half an hour on it, you'll give up and take the pipe off. The top will be in your way otherwise, and I think you'll want to clean out the dirt, swarf and leaves from the box.
p.s.
I think you need a 20mm M6 Stainless Flanged Head screw to refix the box, and I added a form C stainless washer. While you're tinkering under the bonnet you'll see a lot of M6 bolts that want changing, some are 20mm M6 but I think most were about 10mm. I remember the air box screw was longer than most. Lay in a stock and keep them beside the spare wheel. The screws on the undertray will be especially bad.
Old Dec 10, 2013 | 09:29 AM
reyesl's Avatar
I live on a dirt/gravel road (country) with a million dollar view and the local area does get dusty at times (Army Base with Construction Equipment) which is why I clean it monthly. The air filters on Construction Equipment are cleaned daily.
Old Dec 10, 2013 | 01:09 PM
JagV8's Avatar
In the top pic, you can take the tubing off up to the first "jubilee" (curved silver) clip or right up to the supercharger. Unclip MAF connector (the electrical lead near the filter box) first. Don't forget to reconnect it. (Same with any others you need to disconnect - might not be identical to my STR but looks like it.) Also, don't overtighten the jubilee clip when reconnecting. You just need a seal not a strength contest
Old Dec 20, 2013 | 12:46 PM
Jgmc's Avatar
I was able to squeeze the engine filter in it's place without remove the whole cover and not destroying the filter.
Quikcat: To confirm, does the air flow arrow face the interior of the car ( ie looking at reyesl car engine he has an arrow pointing to the cabin filter, does the arrow face that way)or does the arrow face out to the engine.
Thank you to all who has advise this girl on how to do basic things. You saved me a lot of money now and in the future!
Have a Wonderful Holiday Season.
Old Dec 21, 2013 | 03:56 AM
PigletJohn's Avatar
the arrow points to the inside of the car. Sponge out the cavity as it will be dusty and dirty.
BrentGardner
29
Dec 16, 2024 12:13 AM
hafren
Aug 30, 2023 03:42 PM
Series1fan
Sep 5, 2015 08:02 AM
dwgates
Sep 2, 2015 04:09 PM
dpappyp
Aug 27, 2015 06:31 AM
