Intermittent electronics
Old Mar 15, 2015 | 08:28 AM
gmcgann's Avatar
Default Intermittent electronics
I have a couple of odd problems that are increasing in frequency. It's a 2004 XRJ with 99,000 miles. The first problem has happened about 6 or 8 times now, the first maybe a year ago and the last three times in the last week. I start the car and have no audio. Everything on the screen functions normally, I can change source, select tracks, etc., and the display shows a song playing, but no sound. I restart the car and it's fine. It's like the amp isn't being switched on. The audio is completely stock, although I did add the PSE and ACM about three years ago.
The second thing is the driver's seat, starting about a year ago and getting worse as well. I get in and start the car and the seat does not slide forward to the driving position. Sometimes pressing the seat memory button moves it into place, but sometimes that doesn't work either. Restarting the car usually clears the problem, but not always. Sometimes I have to manually use the controls to slide it forward. It has never failed to slide back when I exit the car.
Any ideas where I should start checking this? I have WDS and there are no fault codes.
Old Mar 15, 2015 | 03:21 PM
34by151's Avatar
The memory can go an do wired things with a low battery
The battery can be low even though it starts the car just fine
My suggestion is to replace the battery then see what happens after that
34by151
Old Mar 15, 2015 | 06:13 PM
gmcgann's Avatar
I forgot to mention that I did check the battery right after it happened once - 12.1 volts. The battery is only about 2 years old.
Old Mar 15, 2015 | 06:47 PM
abonano's Avatar
12.1V is kind of low for these cars.I would recommend having the battery load tested
Old Mar 16, 2015 | 12:06 AM
34by151's Avatar
At 12.1 you will fail the battery tests. 12.2 is the absolute minimum
If you battery is 2 years old, get it replaced while you still have warranty
If it out of warranty that tells you a lot bu itself but you could try a peak charger on it but I'd just replace the battery
34by151
Old Mar 16, 2015 | 12:44 AM
Cambo's Avatar
Yeah 12.1V is too low
What happens is when the engine cranks the voltage will drop considerably, if it goes down too low then things start to go weird...
If your voltmeter can record min/max then hook it up to record and start the car, you might be surprised with how low it goes while cranking...
Old Mar 16, 2015 | 12:56 AM
meirion1's Avatar
The audio problem is fairly common but only happened to me about twice in 6 years.
Reason unknown.
I stopped the sliding driver's seat feature when the passenger behind had his knees squashed.
I don't think it helped egress anyway.
To stop it I think I just turned the rotary knob.
Old Mar 16, 2015 | 06:30 AM
rayalbers's Avatar
Low battery voltage could of course also be due to alternator regulation being faulty, so that the alternator charging voltage is too low. Not too likely that the solid state regulator will do that, but worn brushes no longer making good contact with the slip rings could do it. It's be worth measuring the voltage when the engine is running well above idle speed.
Ray
Old Mar 20, 2015 | 11:57 PM
gmcgann's Avatar
Okay, I have 14.4 volts with the engine running and around 12.5 or so when I shut it off. A few hours later I have around 12.1 - 12.2. I let it sit for two days and had 11.9. I'm not showing much of any current draw, so I guess it's time for a battery.
Ferdie
Nov 26, 2018 05:42 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
Moghut
Oct 1, 2015 01:55 AM
Listers
Sep 30, 2015 07:45 AM
