Need help identifying part
Old Apr 21, 2018 | 02:40 PM
Lesh4537's Avatar
Default Need help identifying part
Hello!
I could use some help identifying a part pictured here. This is for my '04 XJ8. There is a loud rattle coming from it. Originally it sounded like an engine knock or tick but it has developed into a rattle that I can hear and feel coming from that part I have indicated.
My second question is in regards to the plastic undercarriage guard. I hit a bag of manure this afternoon while on the freeway and did a lot of damage to the plastic underneath. How important is it replace? A lot of the fasteners were damaged so I'm not even sure I can install a replacement. I'm also not very worried about this but thought I'd ask since I was posting about the above part anyway.
Thanks for the help! ^-^
Old Apr 21, 2018 | 03:48 PM
Aix's Avatar
Aix
That's the breather valve for the high load crankcase ventilation (PCV valve).
The whole thing essentially consists of a spring loaded diaphragm inside which is allowing the slightly increase pressure inside the crankcase to be ventilated into the intake manifold. If it rattles it is probably broken, or you have a serious blowby problem in the engine.
Should be fixed with a certain priority because when this valve doesn't close properly at low engine loads or idle, when there is strong vacuum in the intake manifold, it may lead to several engine problems, including high oil consumption and bad starting behavior.
There is another crankcase ventilation system on bank 2 (the left one in driving direction) which is responsible for scavenging the blowby gas at low loads and idle. That one is only a hose without valve (always open) and has a small calibrate bore underneath to control the maximum gas flow through it at higher load and therefore higher blowby gas flow.
Old Apr 21, 2018 | 05:06 PM
Lesh4537's Avatar
Thank you, Aix! ^-^
Luckily, I already have a service appointment Monday and I'll just at this to the list.
Old Apr 22, 2018 | 12:21 PM
Wingrider's Avatar
The plastic keeps water, dirt, etc, out of the engine compartment, as well as protecting the electrical connections. Useful to keep things as clean as possible.
Old Apr 22, 2018 | 02:09 PM
WLinSTL's Avatar
I agree with Wingrider. Also, if your model year is like mine the alternator is down there mounted on the lower front of the engine and you don't want that getting soaked in wet weather.
Old Apr 22, 2018 | 07:07 PM
Lesh4537's Avatar
Thanks, Wingrider. I do understand its purpose. I'll take what's left of it with me to my mechanic tomorrow. Unfortunately, I don't think it can be saved. Any suggestions if I need to find a replacement? Maybe a part number or proper name?
Old Apr 24, 2018 | 09:55 AM
JRT-MG's Avatar
Parts are listed as "Protection Cover". SNG Barratt has them for just under $40, under Body Metal Panels and Sealing - Fixed Body Panels - Bodyshell Ancillary Panels. Part number is C2C28148 for the left side, there are two part numbers listed for the right side depending on a VIN break.
Dave
Old May 11, 2021 | 03:52 PM
jagnew's Avatar
Originally Posted by Lesh4537
Hello!
Hi Lesh,
I came across this thread today. I do not get the link to the "pictured here". If possible, can you please post the pic here again to understand what part was in question ?
Thanks.
Diamondrmp
Dec 24, 2013 03:22 PM
Palmero
XJ40 ( XJ81 )
Jun 2, 2013 11:58 AM
Romeoc1984
Mar 11, 2013 03:44 PM
Jag_man81
Dec 6, 2011 01:41 PM
Straight6DOHC
Feb 7, 2011 06:57 AM
