Odd electrical isse
Old Jul 29, 2020 | 02:05 PM
mpcook's Avatar
Default Odd electrical isse
Everything working fine until today. Car has been sitting for 3 weeks on a CTEK charger. Everything (as far as I can tell) is working fine except the following: glove box will not open, windows will not operate, sunroof will not operate, and maybe most disturbing, fuel door does not open! As far as I can tell, these items are all on different fuses so there must be something else. I do have what looks to be an original battery in the car, so it is old, but seems to be fine as long as I keep it on charger when it sits for more than a week.
Old Jul 29, 2020 | 04:50 PM
JagV8's Avatar
Load test that battery, it may be OK on voltage but low on power.
Old Jul 29, 2020 | 05:18 PM
meirion1's Avatar
The fuel door can be opened manually if it doesn't open with the button.
Touch battery leads together to reboot vehicle.
Old Jul 30, 2020 | 11:50 AM
mpcook's Avatar
Well, I have decided to replace the battery, so I am hoping a new battery will resolve the issue. My manual is in the glove box, how do I manually open the fuel door?
Old Jul 30, 2020 | 03:39 PM
Fraser Mitchell's Avatar
Has it somehow got into 'valet' mode ?
Old Jul 30, 2020 | 05:21 PM
meirion1's Avatar
Download ownners' manual from this site.
Will have details of fuel door opener.
ie white lever in boot behind liner and near fuel door.
To escape possible valet mode-lock doors and reopen with key.
Old Jul 31, 2020 | 07:57 AM
brian5's Avatar
Fraser, valet mode was my first thought too.
When in Valet mode, the system won't allow other doors to unlock, boot, glove box, probably fuel door too, the manual release is behind the trim in the boot area where the fuel door is, but I'm not sure if that will open the feul door if it is actually locked.
Old Aug 1, 2020 | 06:41 PM
meirion1's Avatar
Why would you need a manual release if the door was not locked?
Root cause possible bad earth behind headlight.
Old Aug 2, 2020 | 03:42 AM
brian5's Avatar
Because the door is electrically operated, locked or not, and if the electrical connection fails, you need to be able to open the door manually
Old Aug 3, 2020 | 06:53 PM
mpcook's Avatar
New battery tomorrow, but in the meantime, I am able to lock and unlock the car, so I don't think I'm in valet mode. I also noticed the mirrors don't move either. So it's a grab bag of items not working. I'll post results of the new battery. Next would be checking the grounds. Thanks for the help.
Old Aug 5, 2020 | 06:01 AM
mpcook's Avatar
New battery yesterday, rebooted the car, everything back to normal. Just a lesson in the importance of having a very healthy battery. As I was driving to get the battery, the steering wheel heat was on. It's warm here in Ohio. Luckily that fixed itself as well.
x1stsacker
Apr 11, 2020 03:41 AM
SteveXJ8L
Oct 30, 2019 11:20 AM
springer
Apr 22, 2016 11:05 AM
aholbro1
22
Jul 15, 2013 08:56 AM
Getghost
Aug 17, 2012 06:43 AM
