does a s-type remote work
Old Nov 4, 2022 | 07:48 AM
Spud Maat's Avatar
Default does a s-type remote work
As the title says i was wondering has anyone tried to program a S-TYPE remote to the X-300?
I was thinking this as they come in both 315mhz and 433mhz but they are the nice flip key style and they use the tibbe blade.
so if they worked it could be a nice easy to source aftermarket solution to get a nice flip key upgrade.
Old Nov 4, 2022 | 09:13 AM
Parker 7's Avatar
The only one that I'm aware is a Saab of a certain model
Is your SLCM marked for a 315
Old Nov 4, 2022 | 12:47 PM
motorcarman's Avatar
The X200/X202 uses a TIBBE key with 6 cut, 4 angle vs 8 cut, 3 angle for the X300/X308.
Old Nov 4, 2022 | 02:10 PM
944play's Avatar
SAAB LTQFM433 (which is 315MHz despite the misleading PN) for 1994-1998 900. Only issue is the "lock" button has a "trunk" pictogram.
Old Nov 4, 2022 | 02:24 PM
Parker 7's Avatar
I have a 315 labeled SLCM and have 2 , 315 FOBs and 1 newly acquired 433
I have yet to program the 433 to see if it works on my 315 SLCM , quick glance at the TSBs says that either FOBs can work just the antenna type has to match the SLCM freq
One of my 315s has some corrosion going on when I had it apart on a bathroom sink so that one is questionable
Old Nov 4, 2022 | 02:32 PM
Parker 7's Avatar
I got it backwards
18-12 (jagrepair.com)
Quote :
" While the SLCM and rear glass antenna do not need to match, the key fob transmitters and the SLCM must be the same frequency. A key fob transmitter of one frequency will not function with an SLCM of the other frequency."
Old Nov 4, 2022 | 05:47 PM
Spud Maat's Avatar
yep well my rear window has 315mhz antenna and my slcm is marked 315.
maybe one day i will find one around here. for now i have my aftermarket system wired in.
which i was thinking at some point to upgrade to push button and remote start system. just because why not.
Old Nov 6, 2022 | 10:32 PM
someguywithajag's Avatar
https://www.jaguarforums.com/forum/x...ictures-93167/
^a while back I came across this thread...
don't know why it keeps linking to page 5...anyhow, the steps are on page 1
Old Nov 7, 2022 | 02:48 AM
Spud Maat's Avatar
Originally Posted by someguywithajag
https://www.jaguarforums.com/forum/xk8-xkr-x100-17/diy-flip-key-conversion-without-reprogramming-guide-pictures-93167/?ispreloading=1
edit the link you have quoted there.
at the end of the link will be /page5 remove that and it will not link to page 5
dopey
Nov 26, 2022 07:07 PM
tmurray
Mar 31, 2015 10:38 AM
soonerpride316
30
Feb 25, 2011 08:42 AM
snooktarpon
19
Apr 10, 2008 05:22 AM
JaguarUSA
May 27, 2007 09:20 AM
