Mufflers
They are a Ford muffler just replaced mine at $53.00 each from Napa Auto Parts.
I don't recall the number but they have a book so we just matched the inlet/outlet and total lenght, what I did do was order the offset in and out but the job would have been easier if I;d have got the in and out pipes straight through..
RJ237 (03-23-2013)
Received 10,757 Likes
They are a Ford muffler?
Or you were able to find a Ford muffler that was close enough to fit?
Not quite the same thing
This is true Doug but I don't see a problem do you?
The old muffler i took off had a serial number on it as did the other side and the one we put one had the very same number. So to be honest mate who cares it's not like these cars are worth a lot so what fits and works and does the job would be fine with me. It's not an issue for me anymore as I got rid of the car a couple of months ago.
If it's the *same* muffler for a smaller price, I'm all for it, believe me ! However, in your own posting it sounds as though there was a fitment problem and you wish you had made a different choice. If that's the case then the bargain price might lose a bit of gloss for some of us.
I might add that mufflers *appearing* the same externally might not be the same *internally*.
Mufflers are generally a boring subject but some of us do care about the details....even on cars that don't have a high market value.
I didn't mean to sound argumentative in my previous posting, sorry.
Me either Doug yes you are right I did have some issues fitting it but it was not the muffler it was the "S" bend piece that allows it to exit the back of the car in the correct location. I wend to the local shop the get them to bend a the piece for me but they were unable to get it tight enough to fit. That's all it was. I am not belittleing the cars at all I grow up in the UK and love them but will not pay hundreds of dollars for a OEM muffler that will rust as fast as one that fits has the same serial number on it for a 1/4 of the price. I'm sorry as well mate did not mean to be argumentative either.
Since I've read that the rear mufflers don't really do much, maybe I'll just use a couple stainless glass pack mufflers. I can get both for less than the cost of a replacement/OEM, and the system would still be somewhat balanced. With the 3-5k miles a year this car will see, that should work out well for a while.
Of course, if I can't repair that rear y-pipe, the whole rear system might get reworked.
baskervillema
10-01-2015 06:43 PM
Woznaldo
09-26-2015 11:02 AM
