oil plug problem
Old Jun 25, 2013 | 04:46 PM
Chris Craddock's Avatar
Default oil plug problem
I just tried draining the oil and the metal hole when the bolt goes for the oil plug is slightly broken off. I can get it tight. does anyone know if I got a longer bolt can I get a seal?
ahhhhhhhh
this car is a nightmare and is costing alot of time and money
plus Im going crazy now!
Old Jun 25, 2013 | 05:28 PM
prestone08's Avatar
May we please have a few photos, im having a hard time envisioning this particular issue.
thank you
Old Jun 25, 2013 | 06:41 PM
avioni's Avatar
im assuming he has a crack on the crankcase right where the threads for the drain plug goes.
if thats it maybe it can be welded for a quick inexpensive fix.
Old Jun 25, 2013 | 07:59 PM
Yes correct
it is cracked and appears to be running down the case as well
Is it a cheap fix
Im very worried I just got the car finally running again :-(
Old Jun 25, 2013 | 11:24 PM
mikesmith2's Avatar
He may be talking about the sump where the plug goes in.
If so you could try JB weld it's a 2 part metal paste, that is less than £5 on Ebay it it may get you out of trouble for a while.
Old Jun 26, 2013 | 01:07 PM
if i replace the oil pan will that take care of that?
Old Jun 26, 2013 | 01:42 PM
mikesmith2's Avatar
If that is where the leak is then yes.
Old Jun 26, 2013 | 09:41 PM
Excellent!
I also have what seems to be a oil leak up higher I posted a few pics but couldnt really see where its coming from
leak from above view beside sparkplugs
Same leak from below
Attached Thumbnails oil plug problem-chris-craddock-137431-albums-94-jaguar-xj6-7478-picture-same-leak-photo-above-19162.jpg   oil plug problem-chris-craddock-137431-albums-94-jaguar-xj6-7478-picture-photo-under-car-leak-coming-above-19163.jpg
Old Jun 27, 2013 | 12:05 PM
mikesmith2's Avatar
Can you take the pics a bit further out so we can see where you are talking about.
Have a look at my post regarding an oil leak, that could be the same area.
kelliott
May 31, 2022 05:26 PM
Gus
Oct 15, 2019 12:29 PM
pnwrs2000
Sep 3, 2015 11:55 AM
OkieTim
Sep 2, 2015 12:48 PM
XJsc-guy
Sep 2, 2015 11:43 AM
