P1775
Old May 5, 2015 | 06:20 PM
Wolfman01869's Avatar
Default P1775
What are the most common causes for this code?
Old May 6, 2015 | 05:41 AM
RJ237's Avatar
What car has the code?
Old May 18, 2015 | 09:10 AM
1996 XJ6. Exhaust Has a fluttering sound on the driver's side at an idle & when you put the car in gear, it gets worse. Touching the gas peddle at all causes the motor to stall out & die before the car even moves. Car has new Catalytic Converters, Plugs & Coils
Old May 18, 2015 | 09:25 AM
Also seems to be backfiring through the throttle body if gas pedal is depressed while the vehicle is in park.
Old May 18, 2015 | 10:12 AM
RJ237's Avatar
P1775 indicates a possible transmission problem, JTIS 21 says read transmission codes, which a generic reader can not do.
I wonder if that is the correct code. Could the reader be in error? Even if the coils are new, there could be a problem with them. Lots of info here on coils if you use search. Also, are the plugs the recommended Champions?
Old May 18, 2015 | 02:29 PM
b1mcp's Avatar
P1775 will be set by an engine stall so it is an effect of the problem you have not the cause of it.
Old May 18, 2015 | 03:45 PM
RJ237's Avatar
If that's the case, I wonder if the throttle body throat and butterfly may be gummed up.
Old May 18, 2015 | 04:49 PM
motorcarman's Avatar
My guess is #5 and #6 coils are reversed.
Just a guess?
bob gauff
Old May 19, 2015 | 10:31 PM
I cleaned the throttle body about a month before this code popped up, replaced the coils & replaced plugs with the recommended plugs. I had driven the car about 40 miles that day, parked it & about 3 hours later, got into it & it seemed to be in what I guess is limp mode & stalled out a few times. It took a long time before the car would start again. ( about 45 minutes each time ) The last time it started, I was able to feather the gas legal to get the car back up to the posted speed limit to get it home & I parked it. Now it starts right up, but has that flutter in the exhaust & the other issues I named above. Other than the flutter, it seems to idle fine, but starts backfiring through the throttle body & any time you attempt to apply very much throttle.
Old May 19, 2015 | 10:52 PM
NBCat's Avatar
'Backfiring' through the inlet manifold is usually an indication of a very lean mixture.
Has the fuel filter been renewed? Have you checked the fuel pump pressure?
Old May 20, 2015 | 11:30 PM
The fuel filter has been replaced. It is about 2 months old. I have not yet checked the fuel pressure. I'll check that & get back to you tomorrow.
Old Jun 1, 2015 | 07:22 PM
Fuel pressure is good. I took a short video of what it is doing, but I don't have a way to convert it so I can post it on here. Do you have an e-mail I could send it to?
AmberJaguar
Jun 10, 2016 04:43 PM
derek15301xjr
Oct 20, 2015 07:39 PM
rsperle
May 16, 2015 12:39 PM
mtbadger
May 16, 2014 08:05 PM
Ben Guzman
Aug 23, 2012 02:23 PM
