I have a slow coolant leak from the water pump area. Is there a way to tell if it's coming from the bearing (assume there's a weep hole somewhere) vs the gasket (o ring?). I tried viewing the area with a mirror and flashlight but no luck - perhaps pulling the pulley would help? I replaced the water pump about 10k miles ago - forget if it was OEM or aftermarket.
I removed the water pump and see some evidence of corrosion across the metal gasket, so I'm pretty certain this was the source of the leak. The manual shows a large o-ring between the gasket and block, but no o-ring was present. I'm assuming only the gasket came with the pump when I replaced it, and that no o-ring was present when I removed the old pump. Can someone confirm the need for the o-ring? Some parts sources list it while others do not. Thanks.
I put in a new water pump a couple of years ago and it came with a paper gasket. Somewhere, I forget where right now, it was recommended to spray both sides of the gasket with Permatex High Tack Spray-A-Gasket. Did that and no leaks.
Yes, most of the replacement pumps come with a gasket.
The gasket material seems to be manufacture preference.
Interesting that they fit on both the 4.0 and 4.2 engines.
I found the AC Delco pump did not leak and was readily available. Use whatever gasket (or not) that comes in the box. But, do the whole top side: stubby connector, crossover, thermostat (housing should be metal already for an R unit), hoses and belt. Same bolts, might as well wrench just once!
Probably a hose in the V. Coolant runs down the outside of hoses and fools you.
I had the blower off and replaced all hoses along with the water pump about 10k miles ago. Here's a pic of the old gasket (right) - about .01" thick metal with a raised bead around all of the ports that compresses when installed. You can see where there was leakage between the center and right chambers - not sure where the leakage was to the outside. The new gasket is .06" thick with rubber gaskets around the outside chambers. I assume I install this dry? Or should I use some gasket compound - I think I have every product Permatex makes - Ultra Black, Hylomar, Ultra Grey, The Right Stuff ... never know which to use in any given application. Appreciate any advice.
You can install it dry or with a smear of silicone.
