97 check engine light
Old Feb 14, 2009 | 09:01 AM
Brutal's Avatar
go to auto parts store, have them pull codes so you know what you have(theres a reason its on and a reason to fix it) and they can clear it too. then tell us what it is and we tell you what to do
Old Feb 14, 2009 | 10:48 AM
Brutal's Avatar
and the point is? get the code and clear it then go from there.....I meen last time I went to the bathroom the light worked fine, then I went in a day later and...nothing light doesnt work???? doesnt matter if 5 minutes or 5 months...it might be a code for low battery voltage, 2ndary air pump flow....or????
may be nothing and probobly is but its nice to know what and not guess
Old Feb 16, 2009 | 01:11 PM
Brutal's Avatar
That the front cylinder, if it returns replace the coil. But you may want to pull that coils and check for oil leaking into the wells from the cam cover leaking. And now you know and can see if, and how soon it returns. If the car sat for 5 months it might have only been alittle gumming of the injector pintle, i add a can of bg fuel system cleaner to the tank, not as good as a flush, but dissolves real light deposits.
Old Feb 16, 2009 | 03:20 PM
Sean B's Avatar
Depending on the reader, there will be an option to clear the fault codes, thus putting the light out. It's standard on any post 2001 Euro cars and 1996 on USA spec' cars.
________
BMW R1200RT
BrentGardner
29
Dec 16, 2024 12:13 AM
big d
Sep 3, 2015 07:37 PM
niner nellie
Sep 1, 2015 10:53 PM
tony bosco
Sep 1, 2015 02:06 PM
daro31
Aug 27, 2015 09:26 AM
