ABS light Traction/stability control
Abs light and traction stability control light keeps popping up.
IT first happened a year ago. Then it went away. Then it happened again then went away. Now it happend a few days ago. Came back today. And has went away in the middle of the day. And is back on when I was on my way home.
What do I do?
1999 Jaguar Xjr
What do I do?
1999 Jaguar Xjr
I have been getting the same thing, no DTCs logged. I made sure my tire pressures were correct (32 psi front/34 psi rear IAW tech data from Merchant Tire and Auto) and it made no difference. Seems like the code is completely random when it pops up.
You can't read C codes from the ECM, these are P codes. Are you reading the ABS module??
An ordinary scanner will read P codes and not C codes (or B codes).
What diagnostic device are you reading the ABS with??
bob gauff
There are no DTCs logged? There should be C codes in the ABS module.
bob gauff
bob gauff
innzane
Sep 2, 2015 10:08 AM
