Any Ideas on How to Pick a Trunk Lock?
Old Mar 4, 2022 | 11:59 AM
FredA101's Avatar
Default Any Ideas on How to Pick a Trunk Lock?
I'm perplexed by this one - The local salvage yard has a 2002 Jaguar XJ8 and I want to buy the SCLM out of it. However, the trunk is locked and cannot be opened. It's obvious someone tried to pry it open and was unsuccessful. I bought a Lisle 8 bite Tibbe lock pick tool as that's what my UK locksmith recommended and thought I could pick the lock. But, when I tried practicing on my own car it acts as if the trunk only has six cylinders as the two barrels nearest the car don't move at all. I can't get my own trunk to open so I have no confidence in my ability once I get to the salvage yard. So, here are my questions?
Am I just no good at this and need to practice more?
Did I buy the wrong tool (do I need a 6 bite tool)?
Is there another way to get the trunk open?
Thanks all.
Old Mar 4, 2022 | 12:14 PM
Addicted2boost's Avatar
If the salvage yard has a key, spray a lubricant in the lock cylinder and use a black key (not the green valet key) to work the lubricant into the tumblers and hopefully unfreeze the lock assembly. I however cannot tell you how to use a lock picking set. Somewhere on this forum has a location to drill a hole to unlatch the lock. Take a hole saw to the junkyard trunk lid??
Old Mar 4, 2022 | 12:22 PM
Parker 7's Avatar
The 4 slots on the trunk license plate attach point if you take the center of these slots and mark a X through them with the center of the X locating the center of the trunk as a whole
This can be done by just taping a piece of paper on the trunk so you can mark it
Drill a hole in the center of the X so you can stick a round shafted Philips screwdriver in
move the handle to the car''s left and you will snag the lock lever to open the trunk
Old Mar 4, 2022 | 12:50 PM
FredA101's Avatar
Hi All,
I located the earlier post with this attached diagram. It indicates I may not have to cut a hole? If I do it's no loss as the trunk lid is destroyed already. Thanks for the help.
Old Mar 4, 2022 | 01:35 PM
Parker 7's Avatar
Just drill a hole big enough to put the screwdriver shaft in
There are better pics coming as I did it myself
You will be moving the lever to the car's right so the screwdriver handle goes to the left
Old Mar 4, 2022 | 02:11 PM
Vauxi's Avatar
Is it out of question to feed power from the engine bay and open the boot via button at the dash ?
Old Mar 4, 2022 | 02:38 PM
Parker 7's Avatar
This would work as long as the positive battery cable is not laying in the battery tray causing a eerie blue glow from the trunk deformed edges
Trunk was never opened after the crash so it is probably still connected
Old Mar 4, 2022 | 02:46 PM
MoXKR's Avatar
Is there any access from the interior through the back seat . There may be an interior trunk release handle that may be accessible through the back seat area. Seems like the XKRs have a yellow handle in the interior trunk ( boot) lid that might be used.
Old Mar 4, 2022 | 04:32 PM
Behind the back seat is the fuel tank.
Old Mar 5, 2022 | 04:39 PM
xalty's Avatar
you can do it with no drilling via the bottom right license plate hole
Old Mar 18, 2022 | 04:11 PM
Probesport's Avatar
I can open my trunk with a 8 cut Tibbe pick, Lishi to be exact, no issues. If you know the basics of lockpicking at all you should be good. Easier than disc detainer, a little harder than a wafer.
The positions that don't move may be because they are at their highest cut. Lockpickinglawyer has a good video on using a Tibbe pick and decoder. This is a 6 position but covers it well
XJL2011
Sep 19, 2024 01:06 PM
Fiatracer
Mar 18, 2022 04:02 PM
maxiedaniels
Sep 5, 2019 12:53 PM
MIFoodie
Nov 13, 2017 05:45 PM
Dan Bennett
Sep 13, 2013 11:13 AM
