Fuel tank removal
Old May 21, 2009 | 08:37 PM
pdesautel@msn.com's Avatar
Default Fuel tank removal
I have a 2000 XJ-8 Vanden Plas with a fuel flow problem the fuel pump wont run. Could it be the crank Positioning sensor? Is there an acess door for the fueltank to remove it from the trunk. So I can replace the fuel Pump. Also how do you remove the back seat Back portion?
Old May 23, 2009 | 09:00 AM
jag_genius's Avatar
The backseat Is held in by screws.. But not needed forthe gas tank removal..It is a big job. Tank come out into the trunk ... Hardest part for you is disconnecting the fuel lines from underneath on top of the diff.. Tank pulls out into the trunk removing few bolts and hoses ..
Old May 23, 2009 | 05:46 PM
Jag-Genuis your right on the money. I was hoping it wouldn't come to that. But I am getting a code on the instrument panel when I try to turn it over (ASC not available also Tach not available could any of these indicators have any thing to do with the fuel pump not running??
Old May 24, 2009 | 05:50 PM
jag_genius's Avatar
thats due to low battery voltage
Old May 25, 2009 | 11:32 AM
Thanks again and again Jag_genuis . Before I try and remove the fuel tank and get to the pump.
I disconnected the connector on top of the Blue cap on the fuel tank and had someone turn the key to on and check with a volt meter from the connector (4 places all four sockets one at a time and it appears that there is no current going to the fuel pump)to ground) I swapped out the fuel pump relay and checked fueses under the hood in the trunk and behind the kick panels under the rear seat.) There is current to the fuel pump relay any suggestions.
Old May 25, 2009 | 08:12 PM
jag_genius's Avatar
does the engine crank?
Old May 25, 2009 | 08:14 PM
jag_genius's Avatar
plug everything back in.. and while your cranking if it cranks.. find the schrader valve on the fuel line.. drivers side front under hood and uncscrew the blue cap and push the vlave in with a screw driver and see if fuel comes out.. will spray a little .. cover your eyes
Old May 26, 2009 | 08:40 AM
Engine does crank,no fuel at schraeder valve. No voltage at the pump. Have 12v at the Relay on the coil side when key is on no voltage on the switch side of the relay.
Old Sep 3, 2012 | 10:14 PM
metasequoiah's Avatar
Default white fuel line removal on jag fuel pump
Do you know how to remove the white fuel line going into the tank? I easily removed the red ones, but the white one will not come out without me breaking it.
Old Sep 4, 2012 | 05:50 AM
steveinfrance's Avatar
@metasequoiah
Please call in at the New Members section and introduce yourself.
If you also add your car details to your signature I will start a new thread for you in the right section.
Old Sep 4, 2012 | 05:53 AM
OP -are you saying there's 12 V across the pump relay coil, 12V input to the relay contacts
but 0v output with the relay connected?
In that case swap the relay for another of the same colour and see if that corrects things.
If not please post exactly what volts on each relay pin with it connected.
dsnyder586
Dec 29, 2024 07:39 PM
hen555
Sep 7, 2015 11:13 PM
alpecsa
Sep 7, 2015 11:55 AM
deanh
Sep 6, 2015 08:20 PM
AL NZ
Sep 4, 2015 08:39 PM
