Headlight switch - operation not as per manual
Morning!
I had a read of my manual after starting to poke about with the controls (the car is new to me, I'm new to North American Jaguars).
However, the headlight stalk doesn't work as I'd expect.
Position 0 has the lights off, that's fine.
Position =(><)= (parking lights) does absolutely nothing (not even the Canadian adaptation) with the key in, out, in any gear position, parking brake on or not.
Position ≡(> (dim lights) brings all the lights on as I would expect for that position, except when the key is removed, and that then leaves the lights as I would expect them in the parking light position.
Seems unusual, is that the norm for cars with the auto headlights feature?
Also, a side note, did the North American cars all say "BOOT OPEN" on the display when you pop the trunk?
--Phil
--Phil
You can change the INSTPK display language.
My sedans have side lights with the switch in the position I or position II with KEY OFF.
The headlamps will work with the KEY ON only.(except the MAIN BEAM FLASH will work without key on.
AUTO will work with TWILIGHT SENTINEL if light is dark enough and KEY ON.
If your car is Canadian, it is different than Federal USA.
It's definitely not a Canadian spec vehicle, so possibly a switch issue, given the parking lights do come on.
Thanks!
Phil
Phil
I would guess that a wire in the multi-function switch has become broken/disconnected?
The switch is also the turn signal switch and is known to have broken wires at the solder joint.
I'll pull the column shroud off and have a look once I'm done fixing all the broken plastics on the gearshift.
Thank you!
I'll dig into it. Appreciate the help!
Phil
