Replace just upper tensioners?
Old Feb 4, 2019 | 07:49 AM
Robert Laughton's Avatar
Default Replace just upper tensioners?
I
Hello,
I know tensioners have been discussed at length. I have a 2000 XJ8, 100,000 miles. I pulled the covers and it needs tensioners.
I'm tempted to just zip tie in the uppers, rather than removing the timing cover, and doing eveything.
I know no one can predict what could happen if I don't replace everything, but am I right that it's the uppers that destroy an engine, and the lowers and guides do not?
I guess I'm looking for reassurance to go cheap/easy.
Thoughts?
Thanks,
Rob
Old Feb 4, 2019 | 08:34 AM
ericjansen's Avatar
With that mileage, I bet your lower guides are cracked, and probably pieces are ripped off and laying in the sump or partially blocking the oil intake.
I have seen several by now, they are all the same.
Yes, you are right in a certain way, the uppers are more critical in case they break down, but lowers can spill havoc too.
I should not go cheap, certainly not with that mileage.
Here is an actual one from the XK forum: https://www.jaguarforums.com/forum/x...s-like-212388/
Old Feb 4, 2019 | 08:37 AM
RJ237's Avatar
I replaced the uppers only on several engines and they're all doing well with up to 40K mi and several years. But if the chain guide plastic starts disintegrating the oil pickup screen could be blocked, potentially destroying the engine, while if a lower tensioner fails the pieces could jam the chain. It's a very rare event, but if you intend to keep the car for many years a total replacement, including chains, would be a wise decision.
Old Feb 4, 2019 | 08:44 AM
Carnival Kid's Avatar
Robert,
It is true that it is the upper tensioners that suffer from earlier deterioration than the lowers, but the lower tension guides crack and begin to break up at a similar time/mileage. This doesn't cause the tooth slippage of the upper chains, but the broken parts of the slipper guides are not desirable in the engine internals, and the lower tensioners are plastic, and I believe will eventually suffer from the same fate as the uppers.
To do the complete tensioner job is a bit of a PITA, but for longevity and peace of mind I would recommend it over just replacing the upper tensioners, especially if you intend to keep the car for several more years.
Here are pics of my lower tensioner guides at 70,000 miles/17 years old.
Old Feb 4, 2019 | 12:25 PM
Highhorse's Avatar
+4 to the previous....replace all and peace of mind will prevail.
Old Feb 4, 2019 | 06:31 PM
Ltd's Avatar
Ltd
Default Debris at 91 thousand miles
Detritus in oil pan. Broken bits from the lower timing chain guides and upper tensioners.
I removed the pickup tube and washed all the broken bits out with hot water and Dawn dish soap in the sink .
Plus the guide rail broke off completely rubbing and could have jammed the crank gears.
​​​​​​​i did the secondary tensoners, still had a nasty rattle. Completed all of it
Old Feb 4, 2019 | 07:03 PM
NBCat's Avatar
False economy to replace just the secondary timing chain tensioners.
Use the correct tools, follow the procedures outlined in the Workshop Manual and replace the primary and secondary timing chains, guides and tensioners.
Old Feb 4, 2019 | 08:00 PM
M. Stojanovic's Avatar
At 75k miles (and 18 years), my primary guides/tensioners had many cracks, luckily no fallen off pieces yet.
Old Feb 4, 2019 | 08:19 PM
If you do decide to take the advice of most here..................
Complete tensioner, chains, gaskets etc.
https://christophersforeigncarparts....ing-in-one-box
Harmonic balancer holding and puller tool
Amazon Amazon
Timing alignment set................
https://www.ebay.com/itm/Engine-Timi...EgC6:rk:4:pf:0
If it hasn't already been done, it is advised to replace the plastic thermostat housing with a metal updated version.
Replace the water pump.
Replace the harmonic balancer bolt.
The harmonic balancer bolt has a recommended torque value of 285lbs ft .............Harbor Freight has a 250lb ft torque wrench for under $100
https://www.harborfreight.com/12-in-...nch-64064.html
Old Feb 5, 2019 | 08:56 AM
Wow! Thank you for all your replies! What a great forum!
I knew I wouldn't get much support for cheaping out with a quick fix on the tensioners.
I guess I was tired after just swapping out the transmission- a big job - and was hoping for an easier next job on the car. The exhaust is the worst part!
I've done the full tensioner job on my VDPSC, so I should just get at it. My local Jag tech will lone me the tools I don't have.
Carnival; those are good prices on the kits, I'll try them.
I've just retired and enjoying my new shop; warm and dry.
Thanks agaian,
Rob
Old Feb 5, 2019 | 09:14 AM
Oh wow.....an auto lift! Talk about being spoiled!
Old Feb 5, 2019 | 04:02 PM
Highhorse's Avatar
Yep, the jealousy factor just ensued...my next place will be a 3 car and a lift with one being a drive through.
Old Feb 7, 2019 | 08:28 AM
Robert Go's Avatar
Just out of curiosity, does anyone know if jaguar ever upgraded the tensioner guides in the later models 2002 or 2003, like they did with the secondary tensioners?
Old Feb 14, 2019 | 12:20 PM
stu46h's Avatar
I'm getting ready to change the timing chains and tensioners. I've already got my loose leaf binder made up with pages printed from the manual with all the procedures, parts, and tools listed that I'll need. Now I'm sourcing the parts and tools, and I just purchased all the parts in one box. I love that idea, thanks for the link. Does anyone have such a kit for the tools, or what is the best source for those?
Old Feb 14, 2019 | 12:52 PM
King Charles's Avatar
Search the forum here, there are a few in-depth threads w/ tool info. etc.
For example :
https://www.jaguarforums.com/forum/x...ng-kit-209618/
https://www.jaguarforums.com/forum/x...r-tool-211507/
https://www.jaguarforums.com/forum/s...rchid=11379189
Old Feb 18, 2019 | 11:29 AM
kansanbrit's Avatar
Yep, plastic uppers are the big risk.
Old Feb 18, 2019 | 11:48 AM
I'm getting ready to change the timing chains and tensioners. Does anyone have such a kit for the tools, or what is the best source for those?
Crankshaft holding tool, and harmonic balancer puller
https://www.amazon.com/Jaguar-Crankshaft-Pulley-Removal-Installation/dp/B01HNY3CVY/ref=pd_ybh_a_28?_encoding=UTF8&psc=1&refRID=247CAB0HBMEKEA4AA2FJ&tag=viglink21907-20 https://www.amazon.com/Jaguar-Crankshaft-Pulley-Removal-Installation/dp/B01HNY3CVY/ref=pd_ybh_a_28?_encoding=UTF8&psc=1&refRID=247CAB0HBMEKEA4AA2FJ&tag=viglink21907-20
Timing alignment tools
blast20
Jan 16, 2012 09:20 PM
oligarh
Jan 10, 2012 12:08 PM
JagYi
Oct 27, 2011 09:59 PM
EZDriver
Mar 7, 2011 08:48 AM
