Tie Rod End Nut
Old Mar 9, 2024 | 08:42 PM
X308TheKingCharles's Avatar
Default Tie Rod End Nut
01 X308
Could someone shed some light on this: are the tie rod ends supposed to have a locking nut? I tried changing my tie rod ends this weekend and it was the most frustrating task ever due to it being rusted and frozen (thanks to the brine and Salt NY uses ) a 30 minute job turned into a 3 hour jobs. Nonetheless after all is said and done - is there a locking nut on our vehicles. According to the SNG Barrett Catalog we are, and from a video showing another x308 replacing tie rod ends there was a locking nut, but not on mine.
edit: specifically asking about the locking nut where the tie rod end attaches to the inner tie rod.
Old Mar 10, 2024 | 07:10 AM
Addicted2boost's Avatar
They came from the factory with nyloc nuts.
Old Mar 10, 2024 | 08:43 AM
M. Stojanovic's Avatar
Originally Posted by X308TheKingCharles
...are the tie rod ends supposed to have a locking nut?...
Which locking nut are you talking about:
Old Mar 10, 2024 | 10:33 AM
motorcarman's Avatar
22mm across-the-flats for the 'jam-nut' or Pal Nut.
Old Mar 10, 2024 | 09:40 PM
I was asking about the one on the actual tie rod (not the nut with the ball joint) but if you know both I could use confirmation of the size. From my research I found that the non ball joint nut is M12, how about the one that attaches to the ball joint end?
Old Mar 10, 2024 | 10:27 PM
Just for clarification purposes only, there’s an inner tie rod end and an outer tie rod end. The inner tie rod end is the long threaded shaft that connects to the steering rack directly. The outer tie rod end connects to the knuckle.
Old Mar 11, 2024 | 12:46 AM
Old Mar 11, 2024 | 07:18 AM
mayhem's Avatar
There most definitely should be a retaining nut on the threaded part of the inner tie rod that you snug up to the outer tie rod end when you install it.
Old Mar 13, 2024 | 03:26 PM
Originally Posted by M. Stojanovic
Perfect, thank you! Is it strange mine did not have a nut (M14) and is it necessary?
Old Mar 15, 2024 | 03:59 PM
Hooli's Avatar
Very necessary, without it the adjustment won't stay in place & worst case the tie-rod unscrews from the ball joint while you're driving.
Old Mar 15, 2024 | 04:07 PM
See post #4
JAM NUT
https://www.wordnik.com/words/jam-nut
olivermarks
Jun 20, 2022 02:48 PM
2004vdp
Mar 15, 2019 06:41 AM
kbeachy
May 1, 2014 05:56 AM
vandenplas408
Jan 8, 2014 04:19 PM
fabfive
Feb 25, 2011 05:19 PM
