Transmission and engine holding back with traction control on...
Old Nov 13, 2008 | 06:02 PM
salsa1's Avatar
Default Transmission and engine holding back with traction control on...
I imagine I am not the only one seeing this as my import mechanic says all XJR's (just about} do it.....while flooring gas at a dry start the engine hesitates massing up the launch...the amber light in the speedometer circle turns on as the engine holds back...making for a not very smooth execution during hard takeoffs...again with traction control off it seems to disappear....will drive a bit more and see..have had the car back from repairs only a short while..but it did this even with the old engine...
comments...anyone been able to fix...or something I need tro live with?
aldo car is smoking only one tire on take offs; doesn't a XJR have factory positraction?
thanks in advance....
Old Nov 14, 2008 | 09:23 AM
salsa1's Avatar
Default RE: Transmission and engine holding back with traction control on...
I am asking if anyones XJR seems to choke when gunned from a dry start..like trying a 0-60 mph dash...??
mine does ...don't know why...mostly with the traction control on....
anyone has a fix for this...?
again thanks...
Old Nov 14, 2008 | 10:30 AM
Brutal's Avatar
THATS THE PURPOSE OF TRACTION CONTROL, ITS SENSES TIRE SPIN AND THROUGH TORQUE LIMITING STRATEGY IN THE ECU, AND TCM STOPS IT. DONT LIKE IT, TURN OFF TRAC CONTROL, AND YES RESETS WITH EACH KEY CYCLE, 1 TIRE SPIN, YES POWER LOCK IN DIFF IS WORN OUT
Old Nov 14, 2008 | 02:31 PM
salsa1's Avatar
Thanks Brutal..is power lock in differential repairable? hasanyone done repair ? parts needed? labor? costs?
thanks for any info....
Old Nov 14, 2008 | 03:56 PM
Brutal's Avatar
YOULL NEED TO TALK TO A DIFF, OR REAR END REBUILDER, JAGUAR ONYL SUPPLIES COMPLETE UNIT, OR ASK KEN IF HE CAN GET THE PARTS AND HAVE SOMEONE DO. BUT I KNOW HE PROBOBLY ALSO SUPPLIES REBUILT DIFFS, AND WOULD BE A BETTER WAY TO GO THAN HAVING SOMEONE REBUILD YOURS THAT MAY OR MAY NOT BE GOOD
Old Nov 14, 2008 | 08:41 PM
salsa1's Avatar
thanks Brutal..Ken is available on this forum somewhere I take it...
Old Nov 14, 2008 | 10:31 PM
Brutal's Avatar
ORIGINAL: salsa1
right here, press 1 for English, 2 for British
Old Nov 14, 2008 | 10:45 PM
Cerberus's Avatar
Brutal, "1 TIRE SPIN, YES POWER LOCK IN DIFF IS WORN OUT"
I've been told this whole time X308s have full open diffs. Is that not true? They have some sort of a locking mechanism? It's not like a regular LSD, I take it, right?
Salsa, Ken's username is "ken@britishparts", he's a helpful guy who works at (owns? iono) a Jag/LR parts warehouse in TX.
BrentGardner
29
Dec 16, 2024 12:13 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
jdzubas
Oct 4, 2015 09:14 AM
Klemen Ošlaj
XE ( X760 )
Sep 22, 2015 07:42 AM
dpappyp
Aug 27, 2015 06:31 AM
