Vacuum Leak
Old Apr 10, 2011 | 02:50 PM
Rickcusaf's Avatar
Default Vacuum Leak
Had the codes read at autozone and it's throwing these:
P1111
P0171
P0174
P0133
P0153
One of the plastic bits that sticks off of the accordian hose is broken and is rigged to stay on right now. I can hear a small hiss coming from this area and I'm wondering if this might be causing the CEL to come on. I don't know enough about jags yet to know where my problems might be.
Also, what is the name of that accordian hose thing? My JTIS is in the mail and I'm having trouble looking up the specific part.
What are those little plastic things for anyways?
Old Apr 10, 2011 | 04:23 PM
jimlombardi's Avatar
Hi Rick
Where is this hose located on the engine? Is it attached to the supercharger?
I think we need more information to be able to help you.
Here is an extract from JTIS about Air Induction System on your XJR:
XJR supercharger diagrams.pdf
Jim Lombardi
Old Apr 10, 2011 | 04:44 PM
Rickcusaf's Avatar
Ah thanks! That makes it so much easier to explain.
It's the Intake Air Distribution and Filtering system.
One of the tuned stubs broke off and the previous owner simply reversed the tube, stuck it back into the hole, and JB welded it in place.
I hear a slight hiss coming from here and I know that if it's removed the engine itself stalls. However I can drive normally like this until I get my new air intake duct.
Can this be the cause of the codes I'm recieving or is that a whole seperate issue?
Old Apr 10, 2011 | 05:02 PM
Gus's Avatar
Gus
First of all please put your car info in your signature. I had to go to your profile to see we are talking about a 2000 xjr.
Any type of vacuum leak on this car will set a code. If you know that you have a leak and you know where it is you need to fix it. This car does not like vacuum leak and will set a code every time and if you think you can patch it with tape I can tell you first hand that band-aid will not hold up. Fix the leaks that you know of and see if your codes will clear.
Old Apr 10, 2011 | 06:18 PM
Rickcusaf's Avatar
The band aid fix is only until my new intake assembly gets here. I'm just going to order a whole new part; and will do on the signature.
Old Apr 10, 2011 | 07:26 PM
Default Part numbers for the Air Pipe from JEPC Parts Catalog
Hi Rick
I looked the Air Pipe on the JEPC (Jaguar Electronic Parts Catalog).
Here is a jpeg file of the page (find your Vin# and get the associated part number):
This part should cost around $38 plus shipping -- if it is part# NNF3555AC (priced at jaguarmerriamparts.com).
Jim Lombardi
Old Apr 10, 2011 | 07:38 PM
Gus's Avatar
Gus
This is my band-aid fix Air Intake Hose Repair only lasted 8 months. I replaced the pipe.
Old Apr 10, 2011 | 07:58 PM
Rickcusaf's Avatar
I think I found the right part.
Collision Catalog - 2000 - Jaguar - XJ
Engine, Air intake, Air pipe, From vin 834576, From vin 834576 - W/supercharger - W/supercharger
I don't have my JEPC yet. That was the only one listed for engines with a supercharger though
My vin ends with F15512
Old Apr 10, 2011 | 09:41 PM
Rickcusaf's Avatar
I just noticed that you're a fellow Airman and a Vietnam veteran to boot.
Thank you Sir (I'm Enlisted too, but I'm also Southern. It's a respect thing!) for helping pave the way for those of us currently in.
Old Apr 13, 2011 | 07:23 PM
Rickcusaf's Avatar
Originally Posted by jimlombardi
Hi Rick
Attachment 9443
Jim Lombardi
How snug should the duct seal fit on the end of the pipe? Mine seems to slide right off and it feels like the pipe itself is just laying on the top of the intake instead of snuggly fitting
Old Apr 13, 2011 | 07:28 PM
Gus's Avatar
Gus
Every pipe connection should seal and fit snug, it is the only way to prevent any vacuum leaks.
Old Apr 13, 2011 | 07:57 PM
Rickcusaf's Avatar
Looks like I need a new seal then. I can hear a hissing coming out of the pipe even after cleaning it.
Old Apr 13, 2011 | 08:07 PM
Gus's Avatar
Gus
Keep in mind this car does not like vacuum leaks. Do not repair with a band-aid do it right and you will reap from the benefits. If the gasket is leaking you may want to check why, they may be cracked or the wrong gasket.
Old Apr 13, 2011 | 09:53 PM
Rickcusaf's Avatar
Hah no worries on band aid fixes. I used to own a corvette and I'm all too familiar with "Bubba".
I'm going to replace it with genuine OEM parts. The Air Pipe is already on order and I'm going to buy a new duct seal for it too.
The worst thing I'd ever seen was someone splicing the radio into a throttle locking cruise control. Every time the radio was turned on it would cause the car to lock into whatever speed it was at and you couldn't disengage without turning the radio off.
Old Jan 26, 2012 | 07:23 AM
jagiam's Avatar
Default air leak on supercharger
Hi can anyone one help,I have an air leak on my supercharger on my 2000 xjr it's making my car idle a bit lumpy,would anyone have an idea what could be leaking?
Old Jan 26, 2012 | 10:18 AM
sparkenzap's Avatar
I will try and be helpful, but it is hard not to sound like a wise ***- You have the car and have identified that it it the SC leaking. Where? How do you know? How are we supposed to know not looking at the car?
If you are asking for where around the SC leaks can form, I would look at the rubber seals where the SC outlet plenum connects to the intercoolers. There are two varieties of rrplacement - one for the AJ 26 and a different one for AJ27. Your's is the AJ 27, I BELIEVE.
Good luck.
Old Nov 18, 2014 | 08:53 PM
san2slim38's Avatar
Default 2001 XJR Supercharger not working properly
I need some serious help ! I was having problems with my airflow meter sensor so I replaced it. as soon a I replaced it; my supercharger started making noises . my car feels feels like it is skipping when it at a stand still. and I can feel air pressure coming from the top of the supercharger . Need help please
Old Nov 18, 2014 | 09:55 PM
Gus's Avatar
Gus
Did you do a hard reset after you changed the MAFS?
Old Nov 18, 2014 | 10:36 PM
Any DTC codes showing now from a current DTC code scan?
Jim Lombardi
clubairth1
30
Sep 3, 2025 04:38 PM
silkcat
Jan 18, 2025 04:29 AM
Bcrary3
Feb 21, 2023 04:29 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
