What is this thing at the bottom of the radiator?
Old Apr 29, 2015 | 09:51 AM
Daim's Avatar
Default What is this thing at the bottom of the radiator?
Hi all!
Looking for the drain plug for my radiator, I stumbled across this:
Now, what is it? It isn't the drain, as that is on the other side of the radiator (right hand). That can be seen on this drawing (part 7):
But what is this on the bottom left corner of my 1998 3.2l V8? Of course NA V8...
Damien
Old Apr 29, 2015 | 10:51 AM
Jhartz's Avatar
Why do you need to know? It looks like it does for the bottom as 3s do on top: holds it in place!
Old Apr 29, 2015 | 11:01 AM
Daim's Avatar
Nope... Can't be that. It is stuck to the radiator and doesn't hold anything...
Old Apr 29, 2015 | 02:32 PM
trucknetjack's Avatar
Looks very much like drain plug, only way to find out open it?.
Catching the coolent
Old Apr 29, 2015 | 03:39 PM
Daim's Avatar
As written, part 7 is the drain plug...
Old Apr 29, 2015 | 04:13 PM
badger2196's Avatar
Yeah, and the part you are talking about doesn't exist in the diagram, so how about just following trucknetjack's suggestion and find out for yourself what it is?
Old Apr 29, 2015 | 04:42 PM
Sean B's Avatar
It is the radiator drain screw, it's plastic and can break if you're not careful - left to loosen.
Old Apr 29, 2015 | 04:51 PM
CharlzO's Avatar
To echo above, that's what it looks like. Perhaps an aftermarket radiator?
Old Apr 29, 2015 | 09:55 PM
motorcarman's Avatar
That is the factory radiator drain plug!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The diagram is for the X300 radiator. Parts catalogues do NOT necessarily have the correct drawings. NOT ALL PARTS ARE DRAWN. Sometimes Supercharged parts that are different have no different illustration.
JEPC can be confusing.
bob gauff
Old Apr 30, 2015 | 12:45 AM
Daim's Avatar
bob gauff
Nope that is the X308 diagramme. This is the X300 diagramme...
And if that was the drain plug, then you would be able to order at least a seal ring or so...
Old Apr 30, 2015 | 06:14 AM
It looks like a drain plug to me part No JLM20628
Old Apr 30, 2015 | 08:12 AM
Daim's Avatar
You are all right... The Jaguar drawings kind of worried me. It is the drain plug. Removed it and a few drop came out... So it is that. But why do they show another plug the other side???
Old Apr 30, 2015 | 08:21 AM
Because that is where the X300 AND XJ40 radiator drain plug is.
bob gauff
Old Apr 30, 2015 | 08:31 AM
Daim's Avatar
As shown, the second picture is from an X300...
I am still man enough to say I was wrong... No need to kick my ***** at the same time
Old Apr 30, 2015 | 11:32 AM
Jhartz's Avatar
I have been confused from gitgo! The part you showed in the photo was the drain plug that is on the left side, rear of the radiator? I failed to blow the photo up.
I guess I need to learn to read, as well.
Old Apr 30, 2015 | 11:56 AM
Daim's Avatar
Yes left side rear...
Old Apr 30, 2015 | 06:55 PM
I always place a stiff sheet of plastic in the front stabilizer bar area to direct the stream of coolant into a drain pan elevated nearly to the bottom of the car when it is on a lift.
If you are doing this on the floor you should be able to put a license plate or something to keep the coolant from missing the pan.
bob gauff
Old May 1, 2015 | 01:35 AM
Daim's Avatar
bob gauff
Great tip Bit my big washing up bowl did the Job great
1100me
Jul 24, 2023 06:10 PM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
timm525
Sep 8, 2015 07:57 PM
1100me
Sep 7, 2015 06:26 AM
