X308 rear hub fulcrum adjustment
Old Mar 29, 2018 | 07:35 AM
MartinQuince's Avatar
Question X308 rear hub fulcrum adjustment
My 1998 XJR s/c was making terrible clonking noises from the rear, hopefully I thought it might be the exhaust banging.
Upon further investigation the rear hub is moving fore and aft on the fulcrum pin.
I've seen diagrams that show adjustment shims but no indication of how tight these should be
Any help appreciated
Old Mar 29, 2018 | 07:47 AM
Welcome to the forum Martin,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
Old Mar 29, 2018 | 11:11 AM
avern1's Avatar
The shims are used for alignment (camber adjustment). The fulcrum bolt and nut are torqued to 88-122 NM's. If you are moving back and forth at the wishbone then most likely the fulcrum bushing are worn out and will need to be replaced.
If you haven't already you need to download JTIS from the how to section for what is necessary to replace the bushings.
Old Mar 29, 2018 | 02:48 PM
Ungn's Avatar
The rear hub fulcrum bolt is just for Toe and the internal roller bearings are rebuildable.
Rear Camber is set using propshaft shims.
Old Mar 29, 2018 | 06:36 PM
avern1's Avatar
+1 ungn, I always confuse camber and toe.
Old Mar 30, 2018 | 02:43 AM
Vern
Thanks for your response, I'm new to this site and find my way around, where is the how to section? Can this bearing replacement be done without special tools?
Old Mar 30, 2018 | 08:57 PM
Ungn's Avatar
Originally Posted by MartinQuince
Vern
Yes, Wrenchs/floor jack/jackstands, nothing special. The Fulcrum bolt is eccentric and sets the rear toe, so note the orientation before loosening/removing it. f the bolt is loose, the toe will be all over the place.
Old Mar 31, 2018 | 11:14 AM
Yes, it was loose, only looked at one side so far, whoopee!
Old Apr 1, 2018 | 09:28 AM
Highhorse's Avatar
Just adding this thread for the rebuild... https://www.jaguarforums.com/forum/x...2/#post1567209
Old Apr 1, 2018 | 10:58 AM
Tips on removing the bearings in bottom of rear hubs? Is it worth replacing the the tube which the long bolt goes through?
Old Apr 1, 2018 | 11:13 AM
The online manual is for a PC which is a problem because I'm on a macintosh?
Old Apr 1, 2018 | 12:30 PM
Highhorse's Avatar
Your going to want to find X308 Workshop on site using the Search and download it...its a PDF. I cannot upload it here because its too large. Starting on pg 284 you will see I believe what you are looking for and scroll down.
The nice thing about the Workshop manual is when you move your mouse over the Table of Contents and you find what you want... "Driveline" in your case and/or sub titles under it. Prompt on it and it will go to it. Beats scrolling through 2500 pgs.
Doug
Jan 29, 2017 10:36 AM
Doug
Jan 25, 2017 10:56 AM
plums
Sep 20, 2015 05:30 PM
gabrielbecheanu
Oct 29, 2013 12:10 PM
Laleekiraly
XJ40 ( XJ81 )
Jul 4, 2010 01:25 AM
