XJ40 ( XJ81 ) 1986 - 1994
'93 just quit...think i figured out,but.... - FIXED
Old Aug 4, 2011 | 10:04 AM
dbrojr's Avatar
Default '93 just quit...think i figured out,but.... - FIXED
i just got this '93 xj6/xj40 from a friend who gave up on it.He was driving it,stopped switched to reverse,it quit,never started again.all electrical power to ing. dead(windows,radio,lock,seats,etc still worked)was at shop for 5months couldnt figure it out.
i brought it home and found a switch behind the drivers side kick panel ,by firewall, was tripped,reset it and runs fine now...but not sure what caused it or why.any info would be greatly appreciated....also gas tank seems to be over-pressurized(blows gas when removing cap)and gets water in it when rains.thanks for any input.
Old Aug 4, 2011 | 02:18 PM
WOW I guess that you got a steal.
That switch is called the Inertia Switch, a safety device that KILLS the car in the event of an accident.
But it can also trip, due to pot holes, curbs etc. For peace of mind, give your tyres a good inspection. A sidewall blowing out at high speed is worrysome, I know.
Re your over pressure tank, you might have a problem with the fuel pressure relief valve. But I'll leave this to one of our experts.
Welcome aboard BTW.
Old Aug 4, 2011 | 03:48 PM
dbrojr's Avatar
thanks for the info...roads around here are really rough,beat up cars alot.....so seems very logical to me.
Old Aug 4, 2011 | 06:30 PM
mrtalkradio's Avatar
It is normal to hear a hiss when opening the gas cap. The water issue, do you mean you can see water around the outside of the gas cap? If that's the case, use your finger to go around the outside of the cap, there is a hole there that the water should drain from. It may be clogged.
Old Aug 4, 2011 | 06:47 PM
dbrojr's Avatar
it hisses when cap is removed,but also squirts gas out,unless open real slow...the water drain seems to be clear,but still seems to fill compartment faster than can drain when it rains....
Old Aug 5, 2011 | 03:07 AM
Cadillac's Avatar
Hmm, mine hisses too , I found it a bit scary though untill I saw mrtalkradio's reply lol
Old Aug 5, 2011 | 08:27 PM
Lumppy47's Avatar
The drain hose might either be plugged up with leaves as they get in there,or it might be crimped somewhere along its path.When clean water flows out quite fast.To clean nine ai used a brazing rod (rounded out on the end) and ran it down and pushed the gunk out of the tube.
Old Aug 18, 2011 | 06:05 PM
dbrojr's Avatar
just an update...got the car on the road and seems to be running ok,a few minor stumbles,but hasnt been run since feb. either....gets better every time i drive it.water now seems to drain from gas cap area good(cleaned the tubing).not as much hissing from gas cap when removing now....removed and cleaned gas tank and refilled with fresh new gas(87 octane) and runs much better now.thanks for all the help...im sure ill be asking alot more questions as time goes by.....
Old Aug 19, 2011 | 04:24 AM
Cadillac's Avatar
Good to see your ride is better than it was
Yu're welcome to ask questions to learn about your ride
Old Aug 20, 2011 | 06:31 PM
roger ele969c's Avatar
I think you'll find it should be run on premium.......Roger.
Old Aug 20, 2011 | 09:56 PM
dbrojr's Avatar
ive searched the archives and have found alot of people are running the low grade...this one seems fine with it...no spark nock or nothing....i run additives for the ethanol and i dont drive it hard(after all its a 4 door sedan not a sport coup).
aholbro1
Dec 29, 2024 06:46 PM
trosty
26
Dec 18, 2022 06:40 PM
Mac Allan
Oct 27, 2015 04:49 AM
Shawn Svacha
Sep 14, 2015 07:38 PM
Darrenmb
Sep 8, 2015 06:12 PM
