1987 XJ6 Manuals ?
Old May 12, 2013 | 11:25 PM
White Jaguar's Avatar
Default 1987 XJ6 Manuals ?
I have 1987 XJ6 base. Can I use a 1986 manuals for reference?
Old May 13, 2013 | 12:18 AM
Doug's Avatar
Default 1978 XJY Manuals?
The only mechanical differences I can think of between an '87 Ser III XJ6 and an '86 Ser III XJ6 are minor:
1) the '87 has a 3-wire oxygen sensor (versus the 1-wire sensor of the '86) and
2) very late '87 cars had a difference a/c compressor protection circuit.
So, yes, an '86 manual should work for for you.
Is it a Haynes manual you are referring to?
Old May 13, 2013 | 02:41 AM
I've moved your question from New Member Area - Intro a MUST section to XJ6 Series I, II & III section. This is the place for model specific questions about your vehicle.
Doug has probably given the answer you need but other members here may have further information to add.
Old May 13, 2013 | 01:15 PM
Fraser Mitchell's Avatar
Question is - is it the XJ6 Series 3 or an early XJ6 later model, (called XJ40 and all squared-off styling with no curves) ?
The later car is totally different
Old May 13, 2013 | 02:24 PM
Doug's Avatar
Which is why I specifically mentioned "Ser III" twice in my reply
Since "White Jaguar" is in the USA I'll go out on a limb and assume the car is a USA-market car. That being case, it would be a Ser III.
But.......
Ya never know !
Old May 13, 2013 | 10:53 PM
Thanks to everyone for your help.
My Jaguar was built in Feb. 1987
Old May 14, 2013 | 12:30 AM
Doug's Avatar
Technically speaking that doesn't settle the identification problem as Jaguar was producing two entirely different cars, both called "XJ6", in Feb 1987.
I'm 99% sure you have a Ser III and not the newer "XJ40"-type XJ6, as the newer style would be tagged "1988" model year in the USA.
This has caused confusion over the years. It is often thought that production of the older style Ser III XJ6 ended in 1986 when, in fact, production of that car ended in April 1987....with the last several months of production intended only for North America.
Meanwhile, full production of the newer "XJ40"-type XJ6 began in 1986, with those cars going to other markets as either 1986 or 1987 model year cars, depending on local practice.
Old May 14, 2013 | 02:04 AM
Time for an XJ6 Picture Quiz!
A. XJ6 Series III
B
. XJ40
Old May 14, 2013 | 06:39 AM
Thanks for the pictures and a little bit of history.
My car is picture A.
My headlights are split with the bonnet.
Thanks again.
Old May 15, 2013 | 04:42 AM
So the answer to your original question is you can use the 1986 manual for a Series 3.
These manuals are a real mine of information and still available on the internet either new or secondhand, (and presumably oil-stained !). The parts manual is also very useful, as it has loads if "exploded" diagrams of the parts and assemblies.
1100me
Jul 24, 2023 06:10 PM
rusty37
Apr 5, 2020 07:40 PM
rusty37
Sep 18, 2015 10:03 AM
1100me
Sep 7, 2015 06:26 AM
Gatsby
Sep 6, 2015 11:52 AM
