Looking for help with IRS
Old Jan 6, 2021 | 08:55 PM
firebird69racer's Avatar
Default Looking for help with IRS
Hello my namw is Wade and I am from Hesperia, Ca.
I am new here. I am working on a Cobra Kit car that has a Jag rear end. I need help in finding replacement rear shocks for it. I have no idea what year or model it is from. The Kit car was built in 78 or 79, so it would have to be out of a car before that. The name and numbers on the shocks are Girling Decarbon 64052458A 3MR8. I have done muliable google searches on that number and found nothing. I ordered some KYB, KG9122 shocks that I thought would fit, but the mounts for the springs that came with them are to big for my springs. There are two tags under the cover bolts, one has 2.85 on it which I think is the gear ratio, as that is about right for the number of turns the pinion makes to get one turn of the axle, the other has a BP.L on it, which I think it means a posi which it has. None of the parts places have dimensions of the shocks, so I can't even go by that. Any help would be appreciated
Thank You all for your time
Wade
Old Jan 7, 2021 | 02:02 AM
Originally Posted by firebird69racer
...... I am working on a Cobra Kit car that has a Jag rear end. I need help in finding replacement rear shocks for it. I have no idea what year or model it is from. .....
Welcome to the forums Wade,
I've copied your post from the New Member Area - Intro a MUST forum to XJ6 & XJ12 Series I, II & III for help and advice from members who will be most familiar with the Jaguar IRS.
Old Jan 7, 2021 | 02:41 AM
Greg in France's Avatar
As long as you retain the springs you have, any Jaguar XJS rear shock will be fine. Standard Boge or better still but pricier, GAZ or AVO adjustables, or any other brand you like.
Old Jan 7, 2021 | 03:28 AM
Andy T.'s Avatar
The KYB part number is 551022
Old Jan 7, 2021 | 07:00 AM
Doug's Avatar
That part number looks correct for 70-80s vintage XJ6-XJ12-XJS
I wonder if your IRS (or at the least the springs?) might be from and E-type/XKE or 60s vintage sedan? The spring may be sized differently on those cars. Just thinking out loud
Old Jan 7, 2021 | 11:28 AM
35olds's Avatar
@69firebirdracer , very interesting post .I'm fairly new here as well , I have a Unique MFG. replica cobra . These guys here really went to bat helping me out with my Jag rear end . I've always been a hot rodder type guy and did not know anything about Jaguars , but these guys sure do . What is your cobra's make ? Look at my posts , they are enlightening , not from me but the help I received .Good Luck with the cobra .
Old Jan 7, 2021 | 01:23 PM
JagCad's Avatar
There seems to be a wild card here. Jaguar salon engineered shcks would not be the best for the much lighter cobra replica. Seems that shicks designed for the E cars would be a better choice.
Decades ago, Carrera shicks were elite. thir tech offered assistance in selction of the right combination. Based on angle of installation and the wieight of the car at the shock location. . Still in existance??? I don't knpo.
Carl
Old Jan 7, 2021 | 04:20 PM
Thank You
Old Jan 7, 2021 | 04:24 PM
That is why I got those shocks, but the spring mounts didn't fit inside the spring. The ID of my springs are 2 1/2" and 9 1/4" long. Do you know if that sounds right for the 70's models?
Old Jan 7, 2021 | 04:35 PM
I too have been working on cars since the early 70's, mostly GM cars and trucks, but never messed with the Jag. I don't know who made this kit there is a tag on the door pillar that says 1979 Cobra, Guldstrand, vin number, Custom Built For Van Parkman, it has the Jag rear end, and a MGB front crossmember and suspenssion, with GM disc brake adapted to it. I have tried to search if Dick Guldstrand ever built Cobra Kits, can't find anything
Old Jan 7, 2021 | 05:37 PM
Here is another pic that shows some numbers and letters stamped on the rear lower right side of the housing, do they mean anything?
Old Jan 7, 2021 | 07:52 PM
kudzu's Avatar
Hi,
It might be made in 73, my 85 diff has a M84 stamped above 6494 in the same area.
Cheers,
Brian
Old Jan 8, 2021 | 02:23 AM
LT1 jaguar's Avatar
Active Streak: 60 Days
At 2 1/2" ID and 9 1/4" long, your springs are considerably smaller that my 1985 XJ6. I'm only mentioning this as an observation, I don't know the dimensions of earlier IRS springs. Couple of pics.
Dave
Old Jan 8, 2021 | 10:59 AM
Originally Posted by kudzu
Hi,
Cheers,
Brian
Thanks, that helped
Old Jan 8, 2021 | 11:01 AM
Dave
Thanks, that looks great
What is the part number on your shocks?
Old Jan 8, 2021 | 03:38 PM
LT1 jaguar's Avatar
KYB KG9122 Gas-a-Just Gas Strut
From Amazon, about $60ea when I bought them in 2019.
Dave
Old Jan 9, 2021 | 11:04 AM
Dave
I bought those and the spring seat did not fit inside my springs, my springs measure 2.5" inside dia.
Old Jan 9, 2021 | 11:08 AM
I talked with a guy at Moss Motors Auto Parts. He looked up my Girling shock number I took off, and he said from the Girling book he has, it shows the shock is from a XJS. Anyone here know the inside dia. of the springs for a 1976 XJS with inboard brakes?
Old Jan 10, 2021 | 03:01 AM
3 inches I.D.
nickdabs
Jul 10, 2020 12:17 AM
Nomen Nescio
Sep 22, 2019 10:45 AM
grumpy1
Jun 23, 2017 02:38 AM
ChristianB
Mar 27, 2016 08:59 AM
woodpuppy
XJ40 ( XJ81 )
Feb 15, 2009 07:54 PM
