Series I with AJ6 engine
Old Sep 24, 2021 | 10:22 AM
  #201
Good Job, Wilfred!
We all Love seeing posts that aren't dealing with some problem or other. Trouble is, When nothing is wrong, we all think we have nothing to report.
NOT SO!!
And, a post like this encourages Newbies here, that a Jag Isn't the POS their friends tell them it is, and they Don't have to run screaming the other way when their SO brings one home.
Maybe more of us should post this sort of thing more often....
Old Oct 12, 2021 | 01:38 AM
  #202
Wilfred88's Avatar
In other news: more happy times with the jag, although the weather is slowly getting a bit more cold and wet:
Old Oct 16, 2021 | 06:23 AM
  #203
metalbasher's Avatar
That's what they were built for. Drive the stink out of it...
Old Dec 22, 2021 | 02:45 AM
  #204
Wilfred88's Avatar
1. So, earlier in this thread I mentioned that I really like the 4.0 AJ6 Engine.
2. Also, I have a VW LT Camper, with a 2,7 liter tractor Diesel engine. We love the camper, but the engine is very slow, and noisy.
Combining point 1 and 2... Put a 4.0 AJ6, including the automatic transmission, in the VW LT!
Get an old, but running xj40. its a 1992 model.
It is rusted, so I don't feel sorry for breaking it:
Cut out all wiring that is not needed for running the engine. I did this while engine was still in the car, so I could test if everything was still working:
That leaves two loom. The engine wiring loom, I will not have to change that. And the loom that powers everything. Basically it's only a couple of 12v feeds, a ignition-on-relay and a starter relay. Below is the loom, I still need to make this much more compact, but it's all I need (and a bit more) to power the engine ECU, transmissen control unit, fuel pump relay etc:
take out the old, diesel engine. It's a Perkins engine btw, from the time that VW didn't have their own diesels yet. As the engine is located between the driver and the passenger seat, it has to come out through the front doors... (or drop the front subframe, but that is much more work)
Next step is to take out the aj6 engine from the donor vehicle, which will hopefully happen this year :-)
Old Dec 22, 2021 | 12:21 PM
  #205
Mkii250's Avatar
This is bonkers and I love it.
Old Dec 22, 2021 | 02:13 PM
  #206
Peter3442's Avatar
Possibly the best thing ever done to a VW!
Old Dec 27, 2021 | 03:27 PM
  #207
Wilfred88's Avatar
Engine out:
This car had an additional gearbox oil cooler. Was that een option at the time?
Old Dec 28, 2021 | 11:45 PM
  #208
Jagboi64's Avatar
Originally Posted by Wilfred88
This car had an additional gearbox oil cooler. Was that an option at the time?
Are you 100% sure that is the transmission cooler? That is usually plumbed into the side tank of the radiator. Instead, that looks like the engine oil cooler. See here: https://parts.jaguarlandroverclassic.../brand/jaguar/
Old Dec 29, 2021 | 02:56 PM
  #209
Wilfred88's Avatar
yeah, you are right. It's an additional oil cooler. I just didn't take a good look at it.
My 1994 4.0 aj6 didn't have this extra oil cooler, seems to be overkill. Even many XJR's don't have it.
Old Dec 29, 2021 | 03:39 PM
  #210
Jagboi64's Avatar
I think it was only installed on European cars intended for high speed/high loads. For your intended use it might be a good idea to keep it.
Old Jan 3, 2022 | 08:58 AM
  #211
Wilfred88's Avatar
Hi all, question for you. I took the engine and gearbox apart. for me this was the first time I seperated an engine and an automatic gearbox. Here in the Netherlands, most (older) cars are all manual, so I didn't have any experience on this
I simply took out the bellhousing bolts, and pulled the gearbox. The engine and gearbox were already out of the car, so I had very good access, and could control the gearbox very well as it was hanging in a lift.
But as you already may suspect, the torque converter was still on the engine. When I saw the engine and gearbox seperated, I thought: hmm, this doesn't look right. And after looking it up, it turns out I could have better unbolted the torque converter from the flexplate and keep the convertor on the gearbox.
Anyway, I am going to install the torque converter back to on the gearbox tonight, and I have read already I have to make sure it is fully seated. but do you have any other tips? I am assuming my convertor will have survived this, but is there something particular to check or to look for ?before putting it back?
Old Jan 3, 2022 | 09:24 AM
  #212
Jagboi64's Avatar
The converter should be put straight on the input shaft of the transmission, making sure it doesn't bind and then offer up the transmission and converter as a unit to the engine. Normially, you'd be checking converter spacing at this point, but since your're putting ti back the way it came it's probably ok. Ideally, you want the converter well seated int eh pump of the transmission, so you don't want a huge amount of play between the flexplate and the converter.
This channel has really good information about automatics, Here is a video about converter spacing:
Old Jan 4, 2022 | 01:47 AM
  #213
Wilfred88's Avatar
Thank you. I carefully inspected all components, and everything looks good. So I placed it back. And I also did some measuring to ensure that the converter was fully seated AND while doing so, I determined that I have around 3mm converter spacing. See pics below:
Oh... and I also did a first testfit.... :-)
Old Jan 7, 2022 | 01:56 AM
  #214
Wilfred88's Avatar
this makes me smile, a Jaguar AJ6 in a VW LT
Engine mounts line up nicely above the subframe
With room to spare on all sides:
Next step: weld the engine mounts. But last night I ran out of welding gas, so have to get a full bottle first
Old Jan 7, 2022 | 11:45 AM
  #215
JagCad's Avatar
Or at one time, VW's of varios types got Corvair flat 6 engines. I almosayt bought a running project.Camper. CA DMV issues. Tougher than the work!
Carlg
Old Jan 26, 2022 | 09:06 AM
  #216
Wilfred88's Avatar
Some progress, engine mounts done. motor in the correct place. Fits perfectly!!!
It's almost a midengined, rearwheel driven racecar!
Old Jan 26, 2022 | 09:30 AM
  #217
Good Job, Wilfred!
Old Jan 26, 2022 | 11:36 AM
  #218
Jagboi64's Avatar
That will make ti the fastest VW camper around!
Old Mar 8, 2022 | 09:11 AM
  #219
Wilfred88's Avatar
I choose to use three coolers. An oil cooler, gearboxoilcooler and of course the radiator.
the found their place. All in free airflow. It's really hard to explain how and where they sit exactly and the pictures are not really clear. But see for yourself:
Old Mar 8, 2022 | 11:32 AM
  #220
Jagboi64's Avatar
The oil cooler is probably not that important, as the North American XJ6's didn't get them and the engines didn't fail. I'm also presuming that you won't be driving the camper at 200 km/h either!
