XJ6 series 1 cutting out
Old Feb 14, 2019 | 03:33 AM
DeanoXJ6's Avatar
Default XJ6 series 1 cutting out
Hi all I've been recommended here by the Jaguar breakfast club.
Hi some help please. Took my XJ6 out yesterday for a run all was good started up fine engine got up to temp then on the back home i did a u turn at a mini roundabout and it died started up agian first time put it in drive and it splutterd a few yards and died, I tried turn the mix up/down same thing i tried putting the revs to 1000 same thing even if I applied to much gas ( foot to the floor) in park revs would stay the same then die, yet normal on the pedal and it was fine. Anyway after an hour i gave up called the AA. When the AA got here the car started fine like always and drove home perfectly. I've drained the fuel and well put fresh stuff in but i dont want to jump to conclusions and blame old fuel as ive had missfire under load before but normally at the start of a drive.
it has had a manual choke conversation.
Old Feb 14, 2019 | 03:24 PM
o1xjr's Avatar
Welcome to the forums Dean, please post an intro in the new member area when time allows for a warm welcome.
https://www.jaguarforums.com/forum/n...-intro-must-5/
Old Feb 15, 2019 | 04:21 PM
David_h's Avatar
Are you saying that it seems to run fine at idle and light load, but cuts out with higher rpm or load? By mix do you mean that you were altering the carb mixture screw? I would think that with a stock setup you adjust the mixture at idle and it should be good for the full range of the engine needs so perhaps it is something else. Have you looked at the spark plugs for fouling or other indications? The other common things to look at are electrical including distributor and vacuum leaks. Also, which carbs do you have?
Old Feb 15, 2019 | 04:41 PM
Robman25's Avatar
Check the temperature of the coil, sounds like its overheating and cutting the spark. When the coil cooled off it fired up again?
Old Feb 16, 2019 | 02:27 AM
DeanoXJ6's Avatar
Yeah it was the fuel mix i was playing with to just try and the car off the busy road i was on i put it back to the original setting. The car would start up and idle fine but as soon as i put it drive it would splutter a few feet then die but start straight away when i turned the key. In neutral it would rev fine but put it in gear and the load of selecting drive caused it to splutter and cut out. I was thinking about changing the coil just in case it has a intermediate problem.
Old Feb 16, 2019 | 02:31 AM
DeanoXJ6's Avatar
SU HS8 carbs
Old Feb 16, 2019 | 07:33 AM
o1xjr's Avatar
Sounds like you have the same set up as me Dean, 4.2 auto with manual chokes and HS8's.
Have a read of the thread linkd below. Once you get past all the general chat there is helpful info in there.
https://www.jaguarforums.com/forum/x...carbys-153356/
Old Feb 16, 2019 | 01:44 PM
DeanoXJ6's Avatar
o1xjr thanks for that link I've been thinking about changing to a "123 ignition " . Did you have the same issue with fireball ok in neutral but in drive/reverse misfire
Old Feb 16, 2019 | 04:21 PM
o1xjr's Avatar
I had all sorts of ignition issues, and mostly under load. I went down the path of carby's, pionts, condenor etc over and over until I bit the bullet and did the conversion to the series 3 electronic ignition and replaced the coil.
Had no trouble from the ignition system for over 3 years now.
HerbieDog
Nov 1, 2014 04:29 PM
markymark
Nov 19, 2013 03:33 PM
hixxy_gsy
Nov 7, 2009 10:12 AM
hixxy_gsy
Oct 21, 2009 10:56 AM
Running Man
Feb 2, 2008 08:32 PM
