90 XJR rims
Old Apr 16, 2016 | 03:08 PM
BC XJS's Avatar
Default 90 XJR rims
Will 18" rims from a 90 XJR fit a XJS or are spacers required. I have a chance to buy 4 with Z rated tires for $400. Bolt patten 5 x 4.5", waiting on exect tire specs
Good deal or not?
Old Apr 16, 2016 | 05:35 PM
ptjs1's Avatar
BC XJS,
Have you got pics of the wheels? Standard wheels on a 1990 XJR are 16" rims.
Paul
Old Apr 16, 2016 | 06:43 PM
BC XJS's Avatar
Here they are
Old Apr 16, 2016 | 07:34 PM
warrjon's Avatar
What width are they?
if they are 8" the offset will be 33, these will fit the rear but will require spacers for the front to increase offset to 20
Old Apr 16, 2016 | 09:37 PM
Doug's Avatar
Good deal or not?
The Jag bolt pattern is 5 x 4.75"....at least until the mid/late 90s.
Better double check what you are getting
Old Apr 17, 2016 | 01:45 PM
Beavis's Avatar
Here they are
I believe the wheels you are referring to are Penta's which were first introduced on the 97\98 V8 XJR.
They do fit, but you will need spacers at the front and possibly small ones at the rear. The fronts you'll need at least 10mm (if you canget away with it) if not 15mm.
Hope that helps..
Rich
Old Apr 17, 2016 | 06:38 PM
BC XJS's Avatar
The tires are 255/45ZR18
Old Apr 17, 2016 | 06:44 PM
warrjon's Avatar
That's the tyre size. You need to know the rim width and offset.
Also if they are off a later model, Jaguar changed the PCD, but I'm not sure when this occurred.
Old Apr 18, 2016 | 01:39 AM
P.L's Avatar
P.L
Hi BC XJS,
The Penta wheels are working for me, see https://www.jaguarforums.com/forum/x...ls-xjs-142094/
I am using 3mm spacers on the front and none on the rears.
Old Apr 18, 2016 | 03:54 PM
BC XJS's Avatar
I just saw the pic. They look good. Thanks for the help
poketastic
May 28, 2016 12:37 AM
OhioMike
Apr 30, 2016 05:44 AM
webbeing
Apr 18, 2016 11:46 PM
convincor
Apr 18, 2016 06:33 AM
JigJag
Apr 16, 2016 10:21 AM
