Engine pics
Old May 11, 2011 | 12:29 PM
i_like_ike's Avatar
Default Engine pics
I've attached some pictures of my engine while I've got the valve covers off. Without the spaghetti maze of wires and hoses running around, it actually looks like an engine!
I've taken pictures of the common problem areas I've read about....Halfmoon seal on back of head (mine leaked) , oil banjo bolt (mine leak, the picture is the one on the sending unit), vaccum advance (frozen), timing adjustment plug (leaks).
Attached Thumbnails Engine pics-smaller.jpg   Engine pics-smaller-2.jpg   Engine pics-smaller-3.jpg   Engine pics-smaller4.jpg   Engine pics-smaller5.jpg
Old May 11, 2011 | 03:49 PM
Adam78's Avatar
i sometimes wish my jag had the v12 in it when i bought it...and sometimes im glad it didnt haha. She is beautiful though!
Old May 11, 2011 | 09:26 PM
JameyXJ6's Avatar
You'd be amazed how much more room there is and how much more you can see if you bypass most of those hoses and pollution controls (Where I live, there isn't emissions regulations on vehicles prior to 96). I have a pile of "extra parts" I've taken off as I've installed the new engine on mine.
Old May 12, 2011 | 12:38 PM
ronbros's Avatar
Default engine pix
my engine after i removved a bunch of stuff, right on, you can actually see the engine .LOL
Attached Thumbnails Engine pics-mazda-jag-rodst-025.jpg   Engine pics-mazda-jag-rodst-027.jpg   Engine pics-mazda-jag-rodst-030.jpg   Engine pics-jag-engine-v12-001.jpg
Old May 19, 2011 | 12:02 PM
i_like_ike's Avatar
Wow! Looks great. I see you took out the A/C, I'd be lying if I said I wasn't considering doing the same thing. Removes alot of clutter and I would guess allows a little better airflow into the V of the engine withouth the pump in there.
Old May 19, 2011 | 01:44 PM
Doug's Avatar
From the "Ask me how I know" files....
In the first picture you can two wires coming out of the distributor. If the connector isn't fully seated the car will conk out 200 miles from home. With so much "stuff" piled over the connector you'll never be able to see the problem while trying to fix the car in the parking lot of an art museum. You'll give up and spend $300 to have the car towed home.
Old May 25, 2011 | 03:46 PM
sidescrollin's Avatar
ronbros how did you make/where did you get that intake setup? similar design to a growler but the diameter looks bigger and doesn't look like it ran your $300+
Old May 25, 2011 | 07:48 PM
ronbros's Avatar
made the elbows from 3" diameter 90*steel tubing ,welded to a flat plate ,cut and finsihed to the 6mm oversize throttle bodies.
tubing around $15. each , and around $20. for the air filters, K&N, 2 for clamps.
works great and low cost,give it a try, nice noise when on the throttle.
you do not need the big TBs, that cost a bit more(lot).
thx for inquiry!
Ron
Old May 25, 2011 | 08:09 PM
man..i wanna learn to weld, i just have a hard time justifying the cost of a welder which i know i won't use all that often.
anyways, thanks for the info it looks great
Old May 25, 2011 | 09:27 PM
JameyXJ6's Avatar
I was in AutoZone autoparts store the other day and found a generic cold air intake setup that looks like it will work. It's plastic and the throttlebody mount looks like it will work nicely with only a little drilling of the plastic for the bolts. I'll post pics of it as I put it together under my "1/2 way done" thread.
God I love this stuff!
Old May 25, 2011 | 10:34 PM
that sounds awesome jamey. When i get my next paycheck i planned on buying 2 airboxes and cutting the openings on them but if there is a legit CAI that can be used with a little modding I would much rather have it.
looking forward to it!
Old May 25, 2011 | 10:46 PM
JameyXJ6's Avatar
They were pretty inexpensive too. I don't recall the brand, but I'll post that too when I pick up the next piece.
Old May 25, 2011 | 11:13 PM
well a new set of airboxes off ebay is like 60 for the pair. Is it similar to that?
Old May 25, 2011 | 11:24 PM
JameyXJ6's Avatar
not exactly. I'm eliminating the airboxes and attaching an adapter directly to the throttlebodies, with a 90 deg elbow and pipe going forwards to pick up the cold air. I'll probably put K&N filters on the ends. The adapter plate was about $6 and I think the elbow was $7-9.
Old May 26, 2011 | 12:49 AM
haha no i just meant similar in price, i was pretty sure i knew what kind of setup you were talking about.
So they are just different plastic pieces desgined to be used for a CAI sold seperately at autozone?? Ill def have to check this out.
Old May 26, 2011 | 04:39 AM
JameyXJ6's Avatar
Yes, they're modular so you can build your own in sections. Some pieces are straight, others are different angles.
Old May 26, 2011 | 05:52 AM
warrjon's Avatar
90mm PVC pipe also works a treat for CAI - paint it black with a can and looks very professional. Have not done it on the XJS yet but have used this with great success on a few other cars
Old May 26, 2011 | 01:00 PM
maybe its because i've been around pvc some, but that would always look like pvc to me lol.
JagBrian
Aug 18, 2019 05:07 PM
cissdm
May 3, 2016 06:02 AM
user 652867429824
Sep 5, 2015 12:53 PM
OkieTim
Sep 2, 2015 12:48 PM
TC Johnson
Sep 2, 2015 09:30 AM
